Found Qupzilla in HaikuDepot but it ‘fatal errored’ while downloading …failed 'flite_x86()
…any suggestions?
…any suggestions?
QupZilla depends on Qt5 which in turnes depends on Flite (A light-weight text-to-speech engine).
Maybe pkgman would show more info? Try top open Terminal and issue:
pkgman install qupzilla_x86
Hi and thanks but I get the same result…no flite_x86()
Wrong repo i suppose…
I suppose It could be something with the repositories but with HaikuDepot your choices and flexibility are limited. The GUI allows All Repos or a choice of Haiku and HaikuPorts.
I use WebPositive but find it a bit flaky at times and related audio, as with Youtube, stuttery and not free flowing. I was looking for a more ‘efficient’ browser.
https://depot.haiku-os.org/#!/pkg/qupzilla_x86?bcguid=bc434-LHJQ
https://depot.haiku-os.org/#!/pkg/qupzilla?bcguid=bc404-WSKT
https://depot.haiku-os.org/#!/pkg/otter_browser_x86?bcguid=bc194-MELO
https://depot.haiku-os.org/#!/pkg/otter_browser?bcguid=bc278-EXLV
I think miqlas meant that the URL of your repo may point to an outdated repo.
Check with the Repository preferences (or “Manage repositories…” in HaikuDepot’s “Tools”) or “pkman list-repos” in Terminal. For 32bit Haiku it should be:
/> pkgman list-repos
Haiku
base-url: https://packages.haiku-os.org/haiku/master/x86_gcc2/current
priority: 1
base-url: https://eu.hpkg.haiku-os.org/haikuports/master/repository/x86_gcc2/current
priority: 1
Thanks for the headsup…will check all this out!
I ran ‘pkgman list-repos’ and the result was exactly the same as yours.
I have Haiku on a usb and tried it in an eeePC but got the same result…
Have you updated recently with “SoftwareUpdater”? I had a quite new and pristine image on a partition. Booted into it, updated and installed QupZilla without problems.
Be careful, there is an “EU” at the begining of the URL.
I havnt noticed that… Maybe you also not.
@humdinger…Unfortunately, software updater also fails with ‘failed to download package Haiku,x86’. My instal, was done at the end of December so I felt it was a recent version.
@kim1953…the eu is there, thanks!
I have a feeling It may be best to start again…a new install may sort out my problems…any suggestions as to the best partition set-up?
…and that is exactly what happened…thanks for persisting with me…new install does everything the way humdinger described.
Software updated and Qupzilla installed!
