compiles for arm and if something does not work in the code, I replace the files from arm64. Will this mixed result code work? compiles on a 64 bit machine
With some magic trick compile a ARM port to image. And the Question is what now ?
I have a files image.mmc + haiku-floppyboot.tgz.efi . how to make a UEFI partition?
