USB Audio sound is working.
Node tree:
Node("Devices Root"): no driver
Node("Device Manager"): system/device_manager/driver/v1
Node("Root subnode"): bus_managers/fdt/driver/v1
Node("Root"): no driver
Node("osc"): drivers/clock/fixed_clock/driver/v1
Node("gmac1_rmii_refin"): drivers/clock/fixed_clock/driver/v1
Node("gmac1_rgmii_rxin"): drivers/clock/fixed_clock/driver/v1
Node("i2stx_bclk_ext"): drivers/clock/fixed_clock/driver/v1
Node("i2stx_lrck_ext"): drivers/clock/fixed_clock/driver/v1
Node("i2srx_bclk_ext"): drivers/clock/fixed_clock/driver/v1
Node("i2srx_lrck_ext"): drivers/clock/fixed_clock/driver/v1
Node("tdm_ext"): drivers/clock/fixed_clock/driver/v1
Node("mclk_ext"): drivers/clock/fixed_clock/driver/v1
Node("jtag_tck_inner"): drivers/clock/fixed_clock/driver/v1
Node("bist_apb"): drivers/clock/fixed_clock/driver/v1
Node("stg_apb"): drivers/clock/fixed_clock/driver/v1
Node("gmac0_rmii_refin"): drivers/clock/fixed_clock/driver/v1
Node("gmac0_rgmii_rxin"): drivers/clock/fixed_clock/driver/v1
Node("clk_rtc"): drivers/clock/fixed_clock/driver/v1
Node("hdmitx0_pixelclk"): drivers/clock/fixed_clock/driver/v1
Node("mipitx_dphy_rxesc"): drivers/clock/fixed_clock/driver/v1
Node("mipitx_dphy_txbytehs"): drivers/clock/fixed_clock/driver/v1
Node("cpus"): no driver
Node("cpu@0"): no driver
Node("interrupt-controller"): no driver
Node("cpu@1"): no driver
Node("cpu@2"): no driver
Node("cpu@3"): no driver
Node("cpu@4"): no driver
Node("soc"): no driver
Node("pmu"): no driver
Node("cache-controller@2010000"): drivers/misc/fu740_cache/driver/v1
Node("aon_syscon@17010000"): drivers/misc/syscon/driver/v1
Node("stg_syscon@10240000"): drivers/misc/syscon/driver/v1
Node("sys_syscon@13030000"): drivers/misc/syscon/driver/v1
Node("clint@2000000"): no driver
Node("plic@c000000"): drivers/interrupt_controllers/plic/driver/v1
Node("clock-controller"): drivers/clock/jh7110_clock/driver/v1
Node("clock-controller@295C0000"): no driver
Node("clock-controller@19810000"): no driver
Node("spi@13010000"): no driver
Node("nor-flash@0"): no driver
Node("otp@17050000"): no driver
Node("usbdrd"): no driver
Node("usb@10100000"): no driver
Node("timer@13050000"): no driver
Node("wdog@13070000"): no driver
Node("rtc@17040000"): no driver
Node("pmu@17030000"): no driver
Node("serial@10000000"): no driver
Node("serial@10010000"): no driver
Node("serial@10020000"): no driver
Node("serial@12000000"): no driver
Node("serial@12010000"): no driver
Node("serial@12020000"): no driver
Node("dma-controller@16050000"): no driver
Node("gpio@13040000"): no driver
Node("uart0-0"): no driver
Node("tx-pins"): no driver
Node("rx-pins"): no driver
Node("mmc0-pins"): no driver
Node("mmc0-pins-rest"): no driver
Node("sdcard1-pins"): no driver
Node("sdcard1-pins0"): no driver
Node("sdcard1-pins1"): no driver
Node("sdcard1-pins2"): no driver
Node("sdcard1-pins3"): no driver
Node("sdcard1-pins4"): no driver
Node("sdcard1-pins5"): no driver
Node("pcie0_perst_default"): no driver
Node("perst-pins"): no driver
Node("pcie0_perst_active"): no driver
Node("pcie0_wake_default"): no driver
Node("wake-pins"): no driver
Node("pcie0_clkreq_default"): no driver
Node("clkreq-pins"): no driver
Node("pcie1_perst_default"): no driver
Node("pcie1_perst_active"): no driver
Node("pcie1_wake_default"): no driver
Node("pcie1_clkreq_default"): no driver
Node("i2c2-0"): no driver
Node("i2c-pins"): no driver
Node("i2c5-0"): no driver
Node("hdmi-0"): no driver
Node("cec-pins"): no driver
Node("hpd-pins"): no driver
Node("gpio@17020000"): no driver
Node("trng@1600C000"): no driver
Node("sec_dma@16008000"): no driver
Node("crypto@16000000"): no driver
Node("i2c@12060000"): no driver
Node("i2c@10030000"): no driver
Node("i2c@10040000"): no driver
Node("i2c@10050000"): no driver
Node("rm68200_panel@45"): no driver
Node("i2c5@12050000"): no driver
Node("eeprom@50"): no driver
Node("axp15060_reg@36"): no driver
Node("sdio0@16010000"): busses/mmc/designware_mmc/driver/v1
Node("MMC Bus Manager"): bus_managers/mmc/driver/v1
Node("sdio1@16020000"): busses/mmc/designware_mmc/driver/v1
Node("MMC Device"): drivers/disk/mmc_disk/driver/v1
Node("vin_sysctl@19800000"): no driver
Node("jpu@11900000"): no driver
Node("vpu_dec@130A0000"): no driver
Node("vpu_enc@130B0000"): no driver
Node("reset-controller"): drivers/reset/jh7110_reset/driver/v1
Node("stmmac-axi-config"): no driver
Node("ethernet@16030000"): drivers/network/dwmac/driver/v1
Node("ethernet-phy@0"): no driver
Node("MII Device"): no driver
Node("ethernet@16040000"): drivers/network/dwmac/driver/v1
Node("ethernet-phy@1"): no driver
Node("gpu@18000000"): no driver
Node("can@130d0000"): no driver
Node("can@130e0000"): no driver
Node("tdm@10090000"): no driver
Node("spdif0@100a0000"): no driver
Node("pwmdac@100b0000"): no driver
Node("i2stx@100c0000"): no driver
Node("pdm@100d0000"): no driver
Node("i2srx_3ch@100e0000"): no driver
Node("i2stx_4ch0@120b0000"): no driver
Node("i2stx_4ch1@120c0000"): no driver
Node("pwm@120d0000"): no driver
Node("spdif_transmitter"): no driver
Node("spdif_receiver"): no driver
Node("pwmdac-transmitter"): no driver
Node("dmic_codec"): no driver
Node("spi@10060000"): no driver
Node("pcie@2B000000"): busses/pci/plda/driver/v1
Node("PCI Bus Manager"): bus_managers/pci/driver/v1
Node("PCI Device"): no driver
Node("PCI Device"): busses/usb/xhci/driver/v1
Node("USB Bus Manager"): bus_managers/usb/driver/v1
Node("USB device"): bus_managers/usb/hub/driver/v1
Node("USB device"): busses/hid/usb_hid/driver/v1
Node("HID Device"): drivers/input/hid_input/driver/v1
Node("USB device"): drivers/audio/usb_audio/driver/v1
Node("pcie@2C000000"): busses/pci/plda/driver/v1
Node("PCI Device"): drivers/disk/nvme_disk/driver/v1
Node("mailbox@0"): no driver
Node("mailbox_client@0"): no driver
Node("dssctrl@295B0000"): drivers/misc/syscon/driver/v1
Node("dc8200@29400000"): no driver
Node("port"): no driver
Node("endpoint@0"): no driver
Node("endpoint@1"): no driver
Node("hdmi@29590000"): no driver
Node("ports"): no driver
Node("mipi@295d0000"): no driver
Node("display-timings"): no driver
Node("timing0"): no driver
Node("dsi-host"): no driver
Node("hdmi-output"): no driver
Node("mipi-dphy@295e0000"): no driver
Node("snd-card"): no driver
Node("simple-audio-card,dai-link@0"): no driver
Node("cpu"): no driver
Node("codec"): no driver
Node("e24@0"): no driver
Node("dsp@0"): no driver
Node("dmc@100b0000"): no driver
Node("aliases"): no driver
Node("chosen"): no driver
Node("memory@80000000"): no driver
Node("reserved-memory"): no driver
Node("opensbi"): no driver
Node("gpio-restart"): no driver
Node("firmware"): no driver
Node("config"): no driver
Node("__symbols__"): no driver
Node("Root subnode"): drivers/null/driver/v1
Node("Root subnode"): drivers/random/driver/v1
Node("Root subnode"): drivers/zero/driver/v1
