Problems writing to USB?
I installed the 1/31/10 nightly build on top of the Alpha R1 release. I can read from 4 GB Sandisk USB drive but I cannot write to it. It is mounted read/write. When I copy using cp file /SANDISK it sits and does not complete. I notice that the USB light blinks randomly. When I pull the disk out I get a kernel panic.
Is this a known issue?
Thanks,
Andrew
I do not think this is a known problem -not that I know of anyway- so you should create a ticket on http://dev.haiku-os.org/ with all the details you can give.
When logged in and at this URL:
http://dev.haiku-os.org/newticket
I get this warning:
■<acct_mgr.web_ui.MessageWrapper object at 0xb85e976c>
and this error:
Error: Forbidden
TICKET_CREATE privileges are required to perform this operation
Hi AndrewZ,
have you created/activated your account at dev.haiku-os.org?
Check out the first few paragraphs of the wiki page.
Regards,
Humdinger
It says I am logged in as andrewz. Do I need an additional activation? Thanks for the assistance.
I’m not sure… Did you get and reply to the activation mail after registering? I have no idea, maybe you can log in without activation, but can’t add a new ticket…?
Maybe try IRC. mmadia should be able to help you, I think.
Regards,
Humdinger
"reply to the activation mail after registering?"
This was the issue. The ticket is submitted, thanks for the assistance.
Very sure your ticket is same as this one:
http://dev.haiku-os.org/ticket/3690
I have no time to check and block it, can someone else do it?
You should look through the older ticket for more information about the issue.
