Problems while using jam
Jam write errors like “can’t find *** target(s)…” or “can’t make *** target(s)…”. Is it possible to list this targets and display reason of error?
Also is it possible to build only haiku.hpkg, not whole image with minimum profile?
Usually it does by default – there’s “don’t know how to make …” in the output before the “can’t make…”
Yes, just add it as a target:
jam -q ... @minimum-raw haiku.hpkg
This will build only haiku.hpkg with the minimum profile. You can do the same under @nightly-raw too, etc.
These questions are probably faster answered on IRC, though; usually at least someone is around and can answer rather quickly. :slight_smile:
You can try:
http://besly.de/index.php/en/internet/vision/setup-vision-irc-client
For easy set up vision IRC…
and/or:
Read the IRC log at: News - Actualités
I tried this with ARM target and package is still silently not produced:
/Haiku/data/packages/haiku/generated.arm> jam @minimum-mmc haiku.hpkg
Starting build of type minimum ...
Building Haiku Minimum Target
AddHaikuImagePackages: package openssl not available!
build-feature packages unavailable on arm: giflib glu mesa ffmpeg fluidlite libvorbis fontconfig gutenprint webkit libpng libicns jasper jpeg libedit qrencode_kdl tiff openexr ilmbase libdvdread libdvdnav libwebp live555 zstd
AddHaikuImagePackages: package bc not available!
AddHaikuImagePackages: package zstd not available!
/Haiku/data/packages/haiku/src/bin/makebootable/platform/efi/Jamfile: No such file or directory
/Haiku/data/packages/haiku/src/tools/makebootable/platform/efi/Jamfile: No such file or directory
don't know how to make @minimum-mmc
...patience...
...patience...
...patience...
...patience...
...patience...
...patience...
...patience...
don't know how to make makebootable
...patience...
...found 79619 target(s)...
...updating 243 target(s)...
...can't find 2 target(s)...
...can't make 154 target(s)...
InitScript1 objects/haiku/arm/packaging/packages_build/minimum/hpkg_-haiku.hpkg/scripts/haiku.package-init-vars
AddTargetVariableToScript1 <unique!target>_target_332
AddTargetVariableToScript1 <unique!target>_target_432
AddTargetVariableToScript1 <unique!target>_target_532
AddTargetVariableToScript1 <unique!target>_target_632
AddTargetVariableToScript1 <unique!target>_target_732
AddTargetVariableToScript1 <unique!target>_target_832
AddTargetVariableToScript1 <unique!target>_target_932
AddTargetVariableToScript1 <unique!target>_target_042
AddVariableToScript1 objects/haiku/arm/packaging/packages_build/minimum/hpkg_-haiku.hpkg/scripts/haiku.package-init-vars
InitScript1 objects/haiku/arm/packaging/packages_build/minimum/hpkg_-haiku.hpkg/scripts/haiku.package-make-dirs
CreateContainerMakeDirectoriesScript1 objects/haiku/arm/packaging/packages_build/minimum/hpkg_-haiku.hpkg/scripts/haiku.package-make-dirs
AppendToContainerMakeDirectoriesScriptAttributes <hpkg_-haiku.hpkg>haiku.package-make-dirs-attributes-dummy-apps
AppendToContainerMakeDirectoriesScriptAttributes <hpkg_-haiku.hpkg>haiku.package-make-dirs-attributes-dummy-preferences
InitScript1 objects/haiku/arm/packaging/packages_build/minimum/hpkg_-haiku.hpkg/scripts/haiku.package-copy-files
AppendToContainerCopyFilesScript <hpkg_-haiku.hpkg>haiku.package-copy-files-dummy-add-ons/kernel/bus_managers
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->usb_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app-<usb>uhci_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app-<usb>ohci_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app-<usb>ehci_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app-<usb>xhci_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->libbe.so_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->libtextencoding.so_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->libtracker.so_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->app_server_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->debug_server_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->dns_resolver_server_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->input_server_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->keystore_server_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->launch_daemon_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->mount_server_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->net_server_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->notification_server_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->package_daemon_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->power_daemon_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->registrar_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->syslog_daemon_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->Deskbar_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->Tracker_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->alert_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->autologin_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->beep_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->bfsinfo_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->catattr_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->checkfs_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->checkitout_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->chop_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->clear_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->copyattr_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->desklink_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->df_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->diskimage_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->draggers_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->driveinfo_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->dstcheck_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->eject_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->error_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->fdinfo_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->ffm_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->filepanel_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->finddir_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->findpaths_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->fortune_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->fstrim_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->getarch_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->hd_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->hey_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->iroster_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->isvolume_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->keymap_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->keystore_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->launch_roster_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->listarea_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->listattr_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->listimage_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->listfont_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->listport_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->listres_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->listsem_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->logger_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->lsindex_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->message_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->mimeset_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->mkindex_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->modifiers_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->mount_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->mountvolume_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->notify_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->open_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->prio_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->ps_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->query_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->quit_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->ramdisk_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->reindex_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->release_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->renice_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->resattr_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->resizefs_mimedb
...on 100th target...
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->rmattr_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->rmindex_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->roster_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->safemode_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->screen_blanker_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->screeninfo_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->screenmode_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->setarch_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->setmime_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->settype_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->setversion_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->setvolume_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->shutdown_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->sysinfo_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->system_time_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->top_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->trash_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->unchop_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->unmount_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->urlwrapper_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->version_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->vmstat_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->waitfor_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->watch_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->xres_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->AboutSystem_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->CharacterMap_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->DeskCalc_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->Devices_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->DiskProbe_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->DiskUsage_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->DriveSetup_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->Expander_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->NetworkStatus_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->ProcessController_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->ShowImage_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->StyledEdit_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->Terminal_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->TextSearch_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->Workspaces_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->Appearance_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->Backgrounds_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app-<preference>Deskbar_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->FileTypes_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->Input_mimedb
GenerateKeymapLocalizationHeader1 objects/common/data/keymaps/KeymapNames.h
C++ objects/haiku/arm/release/preferences/keymap/KeymapWindow.o
Link objects/haiku/arm/release/preferences/keymap/Keymap
XRes1 objects/haiku/arm/release/preferences/keymap/Keymap
SetType1 objects/haiku/arm/release/preferences/keymap/Keymap
MimeSet1 objects/haiku/arm/release/preferences/keymap/Keymap
SetVersion1 objects/haiku/arm/release/preferences/keymap/Keymap
Chmod1 objects/haiku/arm/release/preferences/keymap/Keymap
CreateAppMimeDBEntries1 objects/haiku/arm/release/preferences/keymap/Keymap_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->Keymap_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->Locale_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->Network_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->Notifications_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->Screen_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->Shortcuts_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->Time_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app-<preference>Tracker_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->VirtualMemory_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->STXTTranslator_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->POP3_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->IMAP_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->SMTP_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->MatchHeader_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->SpamFilter_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->NewMailNotification_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->Fortune_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->IPv4Interface_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->IPv6Interface_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->DNSClientService_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->Hostname_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->FTPService_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->SSHService_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->TelnetService_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->FileType_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->Mark as…_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->Mark as Read_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->Open Target Folder_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->Open Terminal_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->ZipOMatic_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app-<input>keyboard_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app-<disk_system>fat_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app-<disk_system>intel_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app-<disk_system>gpt_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app-<disk_system>bfs_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app-<disk_system>ntfs_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb-app->BeDecorator_mimedb
AddDirectoryToContainerCopyFilesScript <hpkg_-haiku.hpkg>data/mime_db/-/<mimedb>mime_db
AppendToContainerCopyFilesScript <hpkg_-haiku.hpkg>haiku.package-copy-files-dummy-add-ons/kernel/busses/ata
AppendToContainerCopyFilesScript <hpkg_-haiku.hpkg>haiku.package-copy-files-dummy-add-ons/kernel/busses/random
AppendToContainerCopyFilesScript <hpkg_-haiku.hpkg>haiku.package-copy-files-dummy-add-ons/kernel/busses/scsi
AppendToContainerCopyFilesScript <hpkg_-haiku.hpkg>haiku.package-copy-files-dummy-add-ons/kernel/busses/usb
AppendToContainerCopyFilesScript <hpkg_-haiku.hpkg>haiku.package-copy-files-dummy-add-ons/kernel/busses/virtio
AppendToContainerCopyFilesScript <hpkg_-haiku.hpkg>haiku.package-copy-files-dummy-add-ons/kernel/console
AppendToContainerCopyFilesScript <hpkg_-haiku.hpkg>haiku.package-copy-files-dummy-add-ons/kernel/debugger
AppendToContainerCopyFilesScript <hpkg_-haiku.hpkg>haiku.package-copy-files-dummy-add-ons/kernel/file_systems
AppendToContainerCopyFilesScript <hpkg_-haiku.hpkg>haiku.package-copy-files-dummy-add-ons/kernel/generic
AppendToContainerCopyFilesScript <hpkg_-haiku.hpkg>haiku.package-copy-files-dummy-add-ons/kernel/partitioning_systems
AppendToContainerCopyFilesScript <hpkg_-haiku.hpkg>haiku.package-copy-files-dummy-add-ons/kernel/drivers/disk/scsi
AppendToContainerCopyFilesScript <hpkg_-haiku.hpkg>haiku.package-copy-files-dummy-add-ons/kernel/drivers/disk/virtual
AppendToContainerCopyFilesScript <hpkg_-haiku.hpkg>haiku.package-copy-files-dummy-add-ons/kernel/drivers/network
...on 200th target...
AppendToContainerCopyFilesScript <hpkg_-haiku.hpkg>haiku.package-copy-files-dummy-add-ons/kernel/drivers/bin
AddSymlinkToContainerCopyFilesScript <hpkg_-haiku.hpkg>add-ons/kernel/drivers/dev/console
AddSymlinkToContainerCopyFilesScript <hpkg_-haiku.hpkg>add-ons/kernel/drivers/dev/dprintf
AddSymlinkToContainerCopyFilesScript <hpkg_-haiku.hpkg>add-ons/kernel/drivers/dev/null
AddSymlinkToContainerCopyFilesScript <hpkg_-haiku.hpkg>add-ons/kernel/drivers/dev/tty
AddSymlinkToContainerCopyFilesScript <hpkg_-haiku.hpkg>add-ons/kernel/drivers/dev/usb_modeswitch
AddSymlinkToContainerCopyFilesScript <hpkg_-haiku.hpkg>add-ons/kernel/drivers/dev/zero
AddSymlinkToContainerCopyFilesScript <hpkg_-haiku.hpkg>add-ons/kernel/drivers/dev/bus/usb_raw
AddSymlinkToContainerCopyFilesScript <hpkg_-haiku.hpkg>add-ons/kernel/drivers/dev/disk/usb/usb_disk
AddSymlinkToContainerCopyFilesScript <hpkg_-haiku.hpkg>add-ons/kernel/drivers/dev/disk/virtual/nbd
AddSymlinkToContainerCopyFilesScript <hpkg_-haiku.hpkg>add-ons/kernel/drivers/dev/dvb/cx23882
AddSymlinkToContainerCopyFilesScript <hpkg_-haiku.hpkg>add-ons/kernel/drivers/dev/input/ps2_hid
AddSymlinkToContainerCopyFilesScript <hpkg_-haiku.hpkg>add-ons/kernel/drivers/dev/input/usb_hid
AddSymlinkToContainerCopyFilesScript <hpkg_-haiku.hpkg>add-ons/kernel/drivers/dev/input/wacom
AddSymlinkToContainerCopyFilesScript <hpkg_-haiku.hpkg>add-ons/kernel/drivers/dev/misc/poke
AddSymlinkToContainerCopyFilesScript <hpkg_-haiku.hpkg>add-ons/kernel/drivers/dev/misc/mem
AddSymlinkToContainerCopyFilesScript <hpkg_-haiku.hpkg>add-ons/kernel/drivers/dev/net/etherpci
AddSymlinkToContainerCopyFilesScript <hpkg_-haiku.hpkg>add-ons/kernel/drivers/dev/net/pegasus
AddSymlinkToContainerCopyFilesScript <hpkg_-haiku.hpkg>add-ons/kernel/drivers/dev/net/usb_asix
AddSymlinkToContainerCopyFilesScript <hpkg_-haiku.hpkg>add-ons/kernel/drivers/dev/net/usb_davicom
AddSymlinkToContainerCopyFilesScript <hpkg_-haiku.hpkg>add-ons/kernel/drivers/dev/net/usb_ecm
AddSymlinkToContainerCopyFilesScript <hpkg_-haiku.hpkg>add-ons/kernel/drivers/dev/net/wb840
AddSymlinkToContainerCopyFilesScript <hpkg_-haiku.hpkg>add-ons/kernel/drivers/dev/ports/pc_serial
AddSymlinkToContainerCopyFilesScript <hpkg_-haiku.hpkg>add-ons/kernel/drivers/dev/ports/usb_serial
AppendToContainerCopyFilesScript <hpkg_-haiku.hpkg>haiku.package-copy-files-dummy-.
AppendToContainerCopyFilesScript <hpkg_-haiku.hpkg>haiku.package-copy-files-dummy-lib
AppendToContainerCopyFilesScript <hpkg_-haiku.hpkg>haiku.package-copy-files-dummy-data/locale/catalogs/x-vnd.Haiku-libmedia
AppendToContainerCopyFilesScript <hpkg_-haiku.hpkg>haiku.package-copy-files-dummy-data/locale/catalogs/x-vnd.Haiku-libpackage
AppendToContainerCopyFilesScript <hpkg_-haiku.hpkg>haiku.package-copy-files-dummy-data/locale/catalogs/x-vnd.Haiku-libtextencoding
AppendToContainerCopyFilesScript <hpkg_-haiku.hpkg>haiku.package-copy-files-dummy-data/locale/catalogs/x-vnd.Haiku-libtracker
AppendToContainerCopyFilesScript <hpkg_-haiku.hpkg>haiku.package-copy-files-dummy-servers
AppendToContainerCopyFilesScript <hpkg_-haiku.hpkg>haiku.package-copy-files-dummy-data/locale/catalogs/x-vnd.Haiku-debug_server
AppendToContainerCopyFilesScript <hpkg_-haiku.hpkg>haiku.package-copy-files-dummy-data/locale/catalogs/x-vnd.Haiku-keystore_server
AppendToContainerCopyFilesScript <hpkg_-haiku.hpkg>haiku.package-copy-files-dummy-data/locale/catalogs/x-vnd.Haiku-mount_server
AppendToContainerCopyFilesScript <hpkg_-haiku.hpkg>haiku.package-copy-files-dummy-data/locale/catalogs/x-vnd.Haiku-notification_server
AppendToContainerCopyFilesScript <hpkg_-haiku.hpkg>haiku.package-copy-files-dummy-data/locale/catalogs/x-vnd.haiku-package_daemon
AppendToContainerCopyFilesScript <hpkg_-haiku.hpkg>haiku.package-copy-files-dummy-data/locale/catalogs/x-vnd.haiku-registrar
AppendToContainerCopyFilesScript <hpkg_-haiku.hpkg>haiku.package-copy-files-dummy-data/locale/catalogs/x-vnd.Haiku-SystemLogger
AppendToContainerCopyFilesScript <hpkg_-haiku.hpkg>haiku.package-copy-files-dummy-data/locale/catalogs/x-vnd.Be-TSKB
AppendToContainerCopyFilesScript <hpkg_-haiku.hpkg>haiku.package-copy-files-dummy-data/locale/catalogs/x-vnd.Be-TRAK
ExtractCatalogEntries1 objects/catalogs/preferences/keymap/en.catkeys
LinkApplicationCatalog1 objects/catalogs/preferences/keymap/en.catalog
File objects/common/data/deskbar/menu_entries
Chmod1 objects/common/data/deskbar/menu_entries
SetType1 objects/common/data/deskbar/menu_entries
InitScript1 objects/haiku/arm/packaging/packages_build/minimum/hpkg_-haiku.hpkg/scripts/haiku.package-extract-files
...skipped 154 target(s)...
...updated 243 target(s)...
Clear generated folder and repeat again give same result. Command is working on x86_64 target.
This is probably why: makebootable is part of the Haiku package, and as it cannot be built, haiku.hpkg cannot be built either.
A stub for EFI makebootable will need to be added, and then things can proceed.
I added stub make_bootable for EFI and haiku.hpkg is now build successfully. I wonder why it build fine before…
It will be nice to have error messages like can't make haiku.hpkg because dependency makebootable is not available instead of silently skipping.
No makebootable is needed for EFI. The dependencies should be fixed so it isn’t used when building for ARM.
It does not fail completely silently. The problem is that it still does other things, which it really shouldn’t if you used the -q switch.This means some dependencies in Jam are strangely defined, or some actions are triggered without a dependency (and indeed I think they are always re-run even if the affected files did not change).
