Problem with checkout svn
I’m getting
Error: Can’t connect to host ‘svn.berlios.de’: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
this are what I have used
TortoiseSVN and the url svn://svn.berlios.de/haiku/haiku/trunk
Other like freeRA I don’t have problem with
Sometimes berlios.de goes down… maybe you just hit it at a bad time.
You can also try the http link in your client:
http://svn.berlios.de/svnroot/repos/haiku/haiku/trunk
look’s like the problem are my connection at work. Where no problem at home :slight_smile:
Ah… possibly a corporate firewall that prevents non-http/ftp connections to the internet.
