Hi!
I have successfully installed Alpha 2 on my Acer Aspire One.
Sound, WiFi, graphics, battery monitor… everything just works!
Except for CodyCam, which cannot connect the data stream to the video window…
Now, as I am starting to use Haiku as my only OS on this computer, I want to be able to use my online bank.
Problem is the following:
I go to my bank’s website.https://www.postbanken.no/
I enter my number (similar to what Americans call a Social Security Number) and press “Bekreft” (Confirm)
The message I get is that my computer does not have Java, so I must log in using a code chip.
This is normal. I do it all the time in Linux when I am on computers whitout Java.
I press on the oval code chip image to the left.
This is when I expect to be able to enter the six digit code that the chip provided.
Instead I get the following error message:
Feilmelding
Du må taste inn fødselsnummeret ditt, 11 siffer. (Feil nr. 1101)
Which roughly translates into:
Error
You must enter your social security number, 11 digits. Error number 1101
But I already did! How did the browser or web site forget that?
I have tried the same several times. It works as expected in Linux, but not in Haiku.
Any ideas, like browser settings or something?
I haven’t changed anything, so everything is default settings.
The browser is WebPositive. It came with the operating system.
