Problem building with gcc 2.95.3 under linux
As I mentioned in the title before I get an build error while compiling with gcc 2.95.3 compiler under linux. With gcc4 compiler i have no problem. But gcc2 compiler gives an error while compiling storage_kit.o … here is the output :
…failed MergeObjectFromObjects1 generated/objects/haiku/x86/release/kits/storage/storage_kit.o …
…removing generated/objects/haiku/x86/release/kits/storage/storage_kit.o
…skipped libbe.so for lack of <libbe>storage_kit.o…
…skipped Deskbar for lack of libbe.so
…skipped <>haiku.image-copy-files-dummy-beos/system for lack of Deskbar…
…skipped haiku.image for lack of <HaikuImage>haiku.image-copy-files…
…failed updating 1 target(s)…
…skipped 4 target(s)…
…updated 1244 target(s)…
when i cd to the directory of src/kits/storage and jam there the output is :
/home/rdmr/develop/haiku/trunk/generated/cross-tools/i586-pc-beos/bin/ld: cannot find -lbe
collect2: ld returned 1 exit status
…failed Link …/…/…/generated/objects/haiku/x86/release/kits/storage/libbeadapter.so …
MergeObjectFromObjects1 …/…/…/generated/objects/haiku/x86/release/kits/storage/storage_kit.o
…failed MergeObjectFromObjects1 …/…/…/generated/objects/haiku/x86/release/kits/storage/storage_kit.o …
…removing …/…/…/generated/objects/haiku/x86/release/kits/storage/storage_kit.o
…failed updating 2 target(s)…
…updated 788 target(s)…
I did checked out from svn many times from scratch, but no luck. I can compile only with gcc4. What problem can it be? Any help will be appreciated.
Thanks.
