Problem booting haiku
Hello problem whit r1 beta 5 on Asus X71SL,kernel panic no roolz desactivo g acpm safe mode etc is bloking.
The r1 beta1 instaled in this portaril but no update repositories vía terminal whit pkgman
This Asus X71SL whit 4 GB de RAM,is máximum RAM suported,gráfica Nvidia 9300 gsm y sis ethernet + wify atheros problems .ethernet conexión detectes but no conectes imposibilites of updated repositories vía terminal
R1 beta 4 y r1 beta 5 en 32 y 64 bytes no arranca se cuelga en arranque.
Help me please
This post would have so much clearer with the help of an AI translation…
I suggest you don’t harass forum members based on the quality of their english in the future.
Hi sugusapple,
Is this a new installation?
The erorr “did not found any boot partitions” means the kernel is confused where it is booting from.
If this is an updated installation:
Did it work before?
If it is try smashing the “space” bar at the start, and then select a previous haiku version in the bootloader, and then report which one worked and which one doesn’t.
Docs for the bootloader are here: Boot Loader
Yes r1 beta 1 rulez in the Asus X71SL but ethernet /wify adapters no conectings,no update Haiku a r1 beta 5 changing repositories whit comands pkgman.
It,s very fast r1beta1 on Asus x71sl but…no internet no update…
It,s fustration for me…sorry for my english.
r1beta1 is quite old, do you have software/data you want to keep? if not you might consider getting a fresh r1beta5 on a usb stick and to try and boot that
Also, your english is fine!
don’t let that comment above discourage you.
Have you tried booting a nightly release as the the issue stopping beta5 from booting may have been resolved since it was released back in September 2024. You can download the nightly releases via this link: https://download.haiku-os.org/
Efectivamente.
R1 beta 1 is operacional in this portátil,but no funciona ethernet no update repositories vía terminal in r1 beta1 con comando pkgman
In the r1 beta 5 in x32 y x64 no load error kernel panic, is terrible r1 beta 1 whit 4 GB RAM is very fast…but no internet whit sis ethernet and wify atheros…drivers Nvidia 930 and Intel is blocked in the BIOS but used plop USB for sustition the BIOS oficial and sort this problem but no roolz r1beta 5
No important for me.only instal haiku new and used old portátil and olvide Windows for limited velocity in this machine.
Thank you download knigtie iso and try this day after …
Ahoy @Sugusapple !
Welcome in Haiku Archipelago !
After I was red this thread I became curious about this Asus machine so I searched, and I opened first – among the results – the Gentoo wiki page.
The user who wrote the article about your hardware wrote the following interesting remark :
Wired network doesn’t work perfectly by default. MTU need to be set to 1492 instead of the default 1500 to work. I don’t know why. This problem happens with systemresc cd, Ubuntu and every Linux distribution I tried.
So if you could setup this MTU setting in R1B1, then the ethernet connection might work for Haiku as well. Then you could upgrade to any hrevXXXXX, especially if you change to Nightly repos.
No, you cannot upgrade to nightly or r1beta5 from r1beta1 via a network connection.
It is possible to upgrade this way, but it requires the installer images of beta2, beta3 and potentially beta4 and is a huge headache and manual process. I would not recomend attempting it.
ok then at least have a Haiku on it – with internet access
I forgot that the availability of specific level repos cutted off, when beta versions switched.
No update repositorirs oficiales ni nightlys
Installing knigjtly but no sound no arranca
The syslog to be written to display should be enabled in the bootloader menu,
and also there - select to switch off syslog paging. Then that way continue with booting …
Then you could share usable infos with the uploaded screenshots – for example where interrupted … if you do not reach the desktop.
Thanks this day for the mourning working…and the 16:00 its time for dedicated time in this haiku solutions.
Thanks for you help.
Hi,Haiku r1 beta 5 knightly instaled…but instaled and reinitialed is fail to final install and kernel panic again.
The fail is acpi monitor led no light …and kernel panic this portátil is very very complicated install distro linux..por other os…it,s bloqued innthe BIOS for Nvidia gráfics Intel grafic and sound …and acpi controles .
More distros and the uniques roolz : Haiku r1 beta1 ,but no internet no funtions sis 191 ethernet…1492 mtu bloqued and kernel panic,comands pkgman.
Asus X71SL is very complicated for reutilized this machine whit others os.
React os roolz but the monitor no light…acpi errors.
This time win 10 pro ltsc in the machine…but this is deseperated for the velocity…
If you have a kernel panic then please make a photograph and put it on our bug tracker :slight_smile:
Hi guys, I finally managed to install Debian 13 Trixie on the Asus X71SL using the pci=nomsi command in the GRUB bootloader. After that, I had to install this command on the hard drive itself to avoid having to do it on every boot. After installing the distro, I noticed that the SiS 191 Ethernet has issues, so I had to use a USB Ethernet adapter. After that, I downloaded updates from the repositories.
However, I still want to use Haiku on this machine because it feels slow with its 4 GB of RAM, so I hope you can give me some guidance on how to emulate this command during the Haiku installation. I haven’t been able to install the Haiku nightlies on this computer, much less R1 Beta 5, because I would need to be able to bypass the MSI instruction check at boot, and I don’t know how to emulate pci=nomsi in the Haiku bootloader.
