hi all
is the ppp source code found in the haiku srcdir in any working/usable state? if so,how can i build it?
running jam -q ppp doesn’t seem to produce any binaries,same thing if try to build one single compnent (ex:jam -q modem),all it says at the end of the jam process is “1 target found”.
No not at all. Think that it need’s to be rewritten to the new Network API.
https://dev.haiku-os.org/ticket/812
But it’s look’s like some one are working on it
thanks for the info,do you happen to know the branch where the changes are being held?
