Powerpc patch porting
Then I have some bug fixes that were done when porting Haiku to PowerPC Pegasos 2 that I will upstream.
Isn’t that code tainted? I don’t think it’s upstreamable then
Tainted: not sure what you mean.
If I understand you correctly, with “when porting Haiku to PowerPC” you meant Tabby (which is a fork, Haiku itself did not get ported to a fully working state on ppc). Tabby uses LLMs quite extensively from what I could tell, so in that regard, the patchsets are tainted and can not be upstreamed (see policies, section copyright policy)
I think it’s okay for us to disagree and still stand together, but it feels like this forum always ends up pushing one side out. That’s really sad.
Hmm, are you willing to provide more details? I certainly haven’t seen that in this thread, but if you have a perspective I’m unaware of, I’m open to hearing about it :slight_smile:
Once again, my post was moved by the administrator from the correct thread to the wrong one. Naturally, it has been taken out of context.
Ya I am not sure why my topic was closed and moved to this one. Completely different topics. @nephele?
You’ve indicated (on the original topic) that the question was answered to your satisfaction, so I moved all the offtopic posts to this new topic and closed the old one… Not every reasonable discussion about AI has to turn into a flamewar… :slight_smile:
do you mean Haiku or tabby/ppc? because haiku on pegasus 2 is incomplete and wont boot even
OK, that makes sense. Just not used to topics being closed. Thanks
