Is Pe editor binary for BeOS available? I only found trial version. I want to use Pe in BeOS for editing code of testing programs used to test BeOS behavior.
I don’t think the current sources are buildable for BeOS but certainly I recall using Pe already back in the days. You’ll want to try searching BeShare.
Try this
http://pulkomandy.tk/~beosarchive//unsorted/BDifferent/Productivity/EDITOR/pe-2.2.3d-x86.tgz.zip
This version run on BeOS, but need registration for saving files. Well, having Pe is not critical, because BeIDE editor is avalible, but it has less functionality.
