Patch for Goldendict needed!
hello
i’ve been trying for 2 days now to compile Goldendict with no success,the code is quite difficult to patch because alot of X stuff are mixed with other code and that makes it difficult for a non-C++ guy like me to patch it.
so, has anyone succeeded compiling this app and cares to share his patch with me?,or is willing to give me hand with patching 1 file and its header? this file is the only thing that’s holding the app from compiling.
the file is: https://github.com/goldendict/goldendict/blob/master/hotkeywrapper.cc
its header is: https://github.com/goldendict/goldendict/blob/master/hotkeywrapper.hh
thanks.
Take a look here:
Thanks alot Diver for your patches, they worked flawlessly ,looking at the way you patched the “hotkeywrapper.cc” file doen’t seem that complicated after all, i just couldn’t find my way around all that X stuff. thanks again.
Heh, those aren’t my patches. They are diger’s :slight_smile:
Ok now i see it on the link,i had asked him privately 2 years ago or so to send me his patch and he said he would do,but he didn’t,he must 've forgotten i guess. in any case thank you both for sharing.
