Opus is a totally open, royalty-free, highly versatile audio codec. Opus is unmatched for interactive speech and music transmission over the Internet, but is also intended for storage and streaming applications. It is standardized by the Internet Engineering Task Force (IETF) as RFC 6716 which incorporated technology from Skype’s SILK codec and Xiph.Org’s CELT codec.
Technology
Opus can handle a wide range of audio applications, including Voice over IP, videoconferencing, in-game chat, and even remote live music performances. It can scale from low bit-rate narrowband speech to very high quality stereo music. Supported features are:
Bit-rates from 6 kb/s to 510 kb/s
Sampling rates from 8 kHz (narrowband) to 48 kHz (fullband)
Frame sizes from 2.5 ms to 60 ms
Support for both constant bit-rate (CBR) and variable bit-rate (VBR)
Audio bandwidth from narrowband to fullband
Support for speech and music
Support for mono and stereo
Support for up to 255 channels (multistream frames)
Dynamically adjustable bitrate, audio bandwidth, and frame size
Good loss robustness and packet loss concealment (PLC)
Floating point and fixed-point implementation
You can read the full specification, including the reference implementation, in RFC 6716. An up-to-date implementation of the Opus standard is also available from http://www.opus-codec.org/.
