Good day,
I also own a Pinephone, the basic (2GB RAM, 16GB emmc -very, very, very low specs for a phone, even a linux phone-) Ubuntu Touch one. While the idea is appealing, it is sitll in a very early stage. I’ve tried almost all distros available on the Pinephone to end up that UT is the one that is “more targeted” to a phone. Also have quite some hardware issues with my device like screen flickering, device turning hot to the level of bending the simcard, issues with network stability… I was never able to use it as a daily driver anyway.
It seems that the Pinephone Pro addresses some of the issues of the original Pinephone, but at more than twice the price. At that price tag, the Volla Phone 22 is more appealing, having also the possibility of multiboot different distros. Also the finishing of the Volla Phone 22 looks more polished than the Pinephone, and priced very close to the Pinephone Pro.
Right now I’m using Lineage on an old Motorola G5s, though the process to get it installed is not straightforward, not as straightforward as loading any distro on the Pinephone. No experience with the Volla Phone as don’t have one.
Nonetheless, the biggest issue I have with any phone is the interface. Usually, interfaces don’t scale well. The only one that did scale properly has already disappeared, Windows Phone. By properly I mean that all the contents of any app resize to fit the window and expand scrolling down, or sliding to next page right, which I haven’t seen on any other interface. Besides the completely black background with white text. While not perfect, UT is the one that I’ve experienced has the best scaling and also has a black background/white text interface, instead of those trending shades of greys/browngreys/bluegreys of today.
The options are scarce and it’s not possible to test them all together to evaluate, as only option is: buy a Pinephone Pro, buy a Volla Phone, buy a regular phone that allows installing Lineage (or other AOSP ROM derivative), put them side by side, compare.
I’ll stick with the Lineage for the time being, while keeping an eye on the Pinephone Pro and the Volla Phone. If their price drops, I might go there.
Regards,
RR
