NX7400 keyboard and touchopad not working
Hi, tried to install R1 alpha1 and then alpha3 to my HP Compaq NX7400 but keyboard end touchpad didn’t worked at all.
Connectin a USB wireless keyboard and mouse worked well.
I red about the problem and it is shown as fixed but how???
Try a nightly image http://haiku-files.org/haiku/development
Done but is the same, I’ll try the alpha4…
Search for linux and freebsd with the same problem to see if other OS have that problem. Can be that linux and FreeBSD has made som patches (not that you can use them in Haiku but then you know if other have had the same problem), perhaps it’s USB3
This are hos I seatch for Wlan that doesn’t work
This should be fixed in alpha 4.1, see http://dev.haiku-os.org/ticket/3594.
