Norhtech Gecko Edubook
http://www.liliputing.com/2009/12/norhtec-gecko-edubook-first-look-netbook-that-runs-on-aa-batteries.html
This would prove interesting if we could get Haiku to run on one of these. I wonder if the specs are doable?
Guru
bump
Should work without to many problems… but might be a bit slow ( the 1GHz Xcore86 CPU thing is probably a lot slower than a normal X86 processor but should be compatible)
Ok thanks for the tip. It just appeared interesting and I thought that Haiku would be compatible with all the components. It would make a great OS for that machine as Haiku itself is rather lightweight.
Guru
