Just a heads up, on the latest Haiku builds your menu sorter isn’t working and I think needs to be recompiled for the ABI break.
To make things easier for people who are running the newer builds and those who are not, you might want to think about having two repos, one pre ABI break and the other post break.
Have you tried the latest yab lib build of bbjimmy? This should fix the problems. I hope so. I does not have ibstallled one of the latest haiku Revisions. The problem are more the side tabs and not the abi break.
I know your thinking, but this is not the problem of the package itself. I set as dependencies “yab” so i should call for the newest version out there.
The problem is that the newest version you need are not in haiku ports at the moment. Only on bbjimmys repo. Bbjimmys repo does not part of haikudepot by default.
I was using yab that was on HaikuPorts and that worked fine, but HaikuDepot didn’t pull that when I installed MenuSorter, I had to manually install yab to get it all working.
