Hi,
New user with latest version, installed and working fine.
I can ping local pc’s and external, Browse Internet etc…
I want to set the “workgroup” to my workgroup_name
Where can I configure workgroup settings.??
Many Thanks…
Hi,
Many Thanks…
Hi
“Workgroup” is a word that means something in Windows but I don’t think it applies in Haiku.
If you want access to Windows-Shares, the only way to do that, is due openjdk and muCommander.
Open a Terminal and paste: pkgman add-repo http://haiku.uwolke.ru/repo/java-ports
After a few seconds you should be able to install muCommander with HaikuDepot.
