ooooohhhhhh some, very very ohsome
SMP is some kind of working. Note two CPU load bars in ProcessController.
QEMU use only one host OS thread for multiple guest CPU emulation so it became even slower with SMP enabled. Currently I know no method how to enable using multiple host OS threads in QEMU.
Desktop with SMP on QEMU is fully working now.
WOW! I hope a cheaper good Risc-V board gets available soon. I was aiming for BeagleV…
Multiple CPU cores are working on real hardware!
Video plays much better. Now it even can play fullscreen, but screen update will become slow because of unsolved slow video memory access problem. Video memory access speed can be improved by using DMA controller that can transfer physical memory without using CPU.
the touhou anime?
I just want to say that I’ve been following your efforts since you started posting and I am extremely impressed, and very grateful for your work. Thank you!
ciao! please, can we have the qemu syntax?
I can’t start your images
I use following QEMU scripts:
haiku_loader.riscv:
/boot/data/packages/haikuports/app-emulation/qemu/work-6.0.0/sources/qemu-6.0.0/build/install/bin/qemu-system-riscv64 \
-machine virt \
-global virtio-mmio.force-legacy=false \
-m 1G \
-bios "/Haiku/data/packages/haiku/generated.riscv64/objects/haiku/riscv64/release/system/boot/riscv/haiku_loader.riscv" \
-serial stdio \
-parallel none \
-monitor none \
-device ati-vga \
-device virtio-blk-device,drive=x0,bus=virtio-mmio-bus.2 \
-device virtio-net-device,netdev=usernet,bus=virtio-mmio-bus.3 \
-drive file="/Haiku/data/packages/haiku/generated.riscv64/haiku-minimum2.image",if=none,format=raw,id=x0 \
-netdev user,id=usernet \
-device nec-usb-xhci,id=xhci \
-device usb-tablet,bus=xhci.0 \
-device usb-kbd,bus=xhci.0
haiku_loader.efi (need u-boot firmware image):
-machine virt \
-m 256M \
-kernel u-boot.bin \
-serial stdio \
-parallel none \
-monitor none \
-device ati-vga \
-device virtio-blk-device,drive=x0,bus=virtio-mmio-bus.3 \
-device virtio-blk-device,drive=x1,bus=virtio-mmio-bus.2 \
-device virtio-net-device,netdev=usernet,bus=virtio-mmio-bus.4 \
-drive file="/boot/data/packages/haiku/generated.riscv64/haiku-minimum.image",format=raw,id=x0 \
-device usb-kbd,bus=xhci.0 \
Latest uploaded version (rev3) is already a bit obsolete, it has some critical problems already fixed.
Running Haiku within Haiku, very interesting… Haiku-ception!
This port is looking very good, if I had a RISC-V machine I’d try it in a heartbeat. Awesome work @X512
i see riscv as being veey useful for embedded use, cnc machines, automotive , portable battery powered.
looks like Haiku being in the first mover group of OS’s, should benefit greatly !!!
this is something haiku promotion team needs to get word out about fast
In theory Haiku can be used in various machines control panel GUI.
Might help in the list of possible use-cases for the nay-sayers.
Linux CNC, it really should be forked, they have a python qt gui to. I don’t know how capable gerbel is, but emc2 delivers for tolerances and control.
has a shit load of cruft and bad design though.
I am not sure if Haiku would run reliably in CNC work, considering it is still beta and prone to crashes. It might poo on very expensive craft.
Amazing Sir!!! I instant want to have this RISC machine!!! <3
only one way to find out, and you start with a parellel install, and run small safe projects and bug hunt, same as everything else.
Loving the progress of this. Makes me want to get a RISC-V hardware and play with it.
