Webkit-gtk successfully built and works fine under Haiku x86 (32bit).
PS: clang rules!
I get these warnings too, but the theme gets applied anyway.
Try renaming the folder to just Haiku (case sensitive), you need the whole folder not just the “gtk-3.0” subfolder.
Mind sharing your recipe (or did you change cmd:gcc with cmd:clang in there)?
I will post an updated recipe today on haikuports.
Actually to switch to using clang you need to add in dependencies: cmd:clang >= 12, gcc_syslibs, gcc_syslibs_devel, libllvm_12 and set environment variables CC="/bin/clang" and CXX="/bin/clang++" before configure.
I made it, thank you very much for you guidance. It was indeed the name of the theme that caused these troubles.
The only thing is that gtk3-demo and Inkscape do not use the Haiku theme and
Claws Mail and Epiphany look a bit ugly.
Is it how it is supposed to be or is there something wrong with the theme?
Maybe related? bluefish, new recipe by Begasus · Pull Request #7435 · haikuports/haikuports · GitHub
Some apps indeed don’t use the theme unless they"re ran from terminal, i don’t know why that is, the gnome apps look weird even in linux, you can disable that extra yellow toolbar by commenting (multi-line style) the whole “headerbar” section in the gtk-3.0 file from line 1528 up to including line 1611.
You can make other tweaks, the changes take effect immediately.
@khallebal @3dEyes already commented on that issue when I was in the progress of creating the recipe for BlueFish, you can find it in the last comment I gave here.
Yeah, i totally forgot the XDG thing.
Just installed webkit-gtk, MiniBrowser crashes when trying to load a page:
wl_ips_client_connected
display: 0x18afa938
client: 0x18afa8b8
(<unknown>:1034): GLib-GIO-WARNING **: 09:01:39.756: Failed to create file monitor for /boot/home/config/settings/glib-2.0/settings/keyfile: Kon de standaard ‘file monitor type’ niet vinden
** (MiniBrowser:951): WARNING **: 09:01:42.565: WebProcess CRASHED
I’ve updated to the latest nightly today (hrev56609) and all wayland based apps (Epiphany, LRRH, Claws, Inkscape and GIMP) crash being unable to find a path related to gdk_pixbuf.
They seem to look for 2.42.9-2 instead of 2.42.9-3.
I tried to revert back to the previous hrev 56595 and they worked until I rebooted again.
I tried to fix this by removing all packages and reinstalling them to no avail.
Has anyone got the same issue?
I solved in the end by uninstalling wayland and all its dependencies. Something went wrong after my previous attempt. The second one succedeed, indeed.
Did you reboot in between uninstalling and reinstalling wayland? I did an uninstall/reinstall without rebooting and still get a crash. Haven’t tried restarting the system yet.
edit: this seems to have made no difference
I uploaded my crash report here, I’m not smart enough to understand exactly where things are going sideways.
https://pastebin.com/raw/Z43QjRiA
Edit: the fix for me was reinstalling gdk_pixbuf
I can confirm the same issue. Uninstalling wayland and gdk_pixbuf and then reinstalling them seems to work.
Yes several times. I’d suggest to remove the packages (namely wayland) by manually deleting the files in /system/packages then checking their presence in /system/packages/administrative/activated-packages
See the pixmap script issue in the following bug report (GTK apps crash gtk_icon_helper assertion (both GIMP and Epiphany) on a particular box. · Issue #7477 · haikuports/haikuports · GitHub). Rerunning the post install script fixes the configuration issues.
For reasons I do not understand, the postinstall script does not run every time a package is installed/updated. This seems to be a problem with the Haiku’s package manager.
4 posts were split to a new topic: Worker (file manager)
I implemented proper Wayland global object handling and added support of multiple clients. Multiple clients is needed for GTK 4 inspector that is now working.
Source code: introduce and use WlGlobal, support multiple clients · X547/wayland-server@10647e7 · GitHub
