My progress in porting Wine
Oh, makes sense. I’m guessing OpenGl then will work in Wine using Zink eventually. Cool!
Wine on Haiku currently has significant performance problem caused by poll() in wine_server. It spends significant time in kernel. wine_server seems designed to use epoll that is not available on Haiku.
screenshot126
screenshot127
I spend last days to creating Haiku native windowing intergation driver for Wine winehaiku.drv without using X11 or Xlib in any way. It is already quite usable and outperforms winex11.drv + Xlibe in many aspects.
Native Haiku Wine windowing intergation driver will also simplify Vulkan and DXVK integration a lot, no GLX stuff.
What works:
  1. Displaying window contents. Wine drawing engine is used, drawing result is displayed with BView::DrawBitmap().
  2. Mouse input (left, right, middle buttons, wheel).
  3. Keyboard input (VK_* codes translation, Haiku native keymap handling).
  4. Native Haiku window borders and window styles.
  5. Windows move, resize, show/hide.
What do not work:
  1. Focus contol.
  2. Window Z-order control.
  3. Wine - Haiku window position syncronization sometimes works wrong.
  4. Detecting screen size.
screenshot141
screenshot142
This is really nice.
Soon we will have a lot of windows applications that will work better than other platforms, especially due to the lightness of HAIKU which uses the minimum of available resources, giving all the rest of the resources to the applications, as it should be.
Philosophizing, HAIKU now is beautiful because it is orderly, elegant and essential.
The other os are fat and a bloated chaotic and bureaucratic waste of resources.
HAIKU attracts because this free lightness is projected on the psyche of our consciences, and in this historical phase there is a great need for this free lightness.
I just can’t get over how decent they look. ya, not native, but not bad either.
It should be noted that Wine on Linux is still struggling with its transition to Wayland. So in some ways the Haiku port is already superior.
This seems like the best solution. Any chance of Wine accepting the patches, and maybe supporting Haiku?
Thats a very good idea!
That looks quite good and the menus seem to be in the correct positions, unlike Wine on native Wayland without a virtual desktop. In that sense, it is already farther along than that other effort. Perhaps as a future task, look into creating a Haiku-like Windows theme?
Or something like uxtheme → BControlLook integration.
Maybe nonsense (I’m a bit inexperienced…), but I still have a CD somewhere with a 3D CAD (including photogrammetry, etc.) that I could look for … if there was even the possibility …
Requirements at that time:
Pentium PC from 200 MHz, 64MB RAM, 100MB memory,
for Win95 / 98 / ME / NT / 2000 (was queried during installation, i.e. ‘adapted’).
this would be really fun, I can’t wait to see some famous windows application, entirely with the haiku skin :joy:
Yeah, next time JLG will have better chance to post an actual Be/Haiku screenshot.
(Not like last time where he posted a reskinned windows screenshot as BeOS).
Is this theoretically feasible? Even on platforms officially supported by CodeWeavers (Linux, macOS), Wine doesn’t do similar kinds of integrations with GTK, Qt, or Cocoa.
Windows 98, 2000 etc supported custom colors for normal winforms controls, it should be possible to have this be based on Haiku colors atleast.
Wine already has a theme selector build in aswell, that no linux distro makes use of this for integration is kind of wierd : )
A thread spending over half its time in poll() likely indicates either one of two things: there are thousands of FDs being run through poll (this seems rather unlikely if you only have one WINE application working), or there is an event being triggered every time poll is invoked, or within a few ms at most (much more probable.) This may be due to a bug of some sort either in WINE or in Haiku; possibly there is some error condition not being cleared. It is worth investigating on the WINE side of things to see what is precisely happening.
250 fd when running notepad. 264 fd when running image viewer with animation. According to my SystemManager, new sem_id with name “select” is created on each poll() call.
That’s a lot of FDs! Why so many? How often does poll wake up?
Note that all Win32 synchronization primitives (semaphore, event, etc.) are implemented on wineserver side. wineserver is single threaded with one global event loop.
Yes, as in a Haiku-like Windows theme/colour scheme. What @X512 seemed to propose was not a theme, but rather integration between UXTheme and BControlLook.
It is odd, but perhaps it is avoided since Windows apps would prolly break too much due to the large gap in design between most Linux themes and Windows Classic. Maybe a Haiku-like theme will work better, since Haiku and Windows Classic both have similar designs from the 90s?
