My Haiku LoongArch (UEFI) port progress
I tried “–verbose” for gcc,
Configured with: /home/dev/haiku/buildtools/gcc/configure --prefix=/home/dev/haiku/generated.loongarch64/cross-tools-loongarch64 --target=loongarch64-unknown-haiku --disable-nls --disable-shared --with-system-zlib --enable-languages=c,c++ --enable-lto --enable-frame-pointer --enable-__cxa-atexit --enable-threads=posix --with-default-libstdcxx-abi=gcc4-compatible --with-sysroot=/home/dev/haiku/generated.loongarch64/cross-tools-loongarch64/sysroot --disable-maintainer-mode --disable-libgomp --disable-libatomic --with-arch=loongarch64 --disable-multilib
Thread model: posix
Supported LTO compression algorithms: zlib zstd
gcc version 13.3.0 (GCC)
COMPILER_PATH=/home/dev/haiku/generated.loongarch64/cross-tools-loongarch64/lib/gcc/loongarch64-unknown-haiku/13.3.0/:/home/dev/haiku/generated.loongarch64/cross-tools-loongarch64/lib/gcc/loongarch64-unknown-haiku/13.3.0/:/home/dev/haiku/generated.loongarch64/cross-tools-loongarch64/lib/gcc/loongarch64-unknown-haiku/:/home/dev/haiku/generated.loongarch64/cross-tools-loongarch64/lib64/gcc/loongarch64-unknown-haiku/13.3.0/:/home/dev/haiku/generated.loongarch64/cross-tools-loongarch64/lib64/gcc/loongarch64-unknown-haiku/:/home/dev/haiku/generated.loongarch64/cross-tools-loongarch64/lib64/gcc/loongarch64-unknown-haiku/13.3.0/../../../../loongarch64-unknown-haiku/bin/
BELIBRARIES=/home/dev/haiku/generated.loongarch64/cross-tools-loongarch64/lib64/gcc/loongarch64-unknown-haiku/13.3.0/:/home/dev/haiku/generated.loongarch64/cross-tools-loongarch64/lib64/gcc/loongarch64-unknown-haiku/13.3.0/../../../../loongarch64-unknown-haiku/lib/:/home/dev/haiku/generated.loongarch64/cross-tools-loongarch64/sysroot/boot/system/develop/lib/
COLLECT_GCC_OPTIONS='-O2' '-v' '-static-libgcc' '-o' 'isl_test_cpp' '-mabi=lp64d' '-march=loongarch64' '-mfpu=64' '-mcmodel=normal' '-mtune=la464' '-dumpdir' 'isl_test_cpp.'
 /home/dev/haiku/generated.loongarch64/cross-tools-loongarch64/lib/gcc/loongarch64-unknown-haiku/13.3.0/collect2 -plugin /home/dev/haiku/generated.loongarch64/cross-tools-loongarch64/lib/gcc/loongarch64-unknown-haiku/13.3.0/liblto_plugin.so -plugin-opt=/home/dev/haiku/generated.loongarch64/cross-tools-loongarch64/lib/gcc/loongarch64-unknown-haiku/13.3.0/lto-wrapper -plugin-opt=-fresolution=/tmp/ccljMgmi.res -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lroot -plugin-opt=-pass-through=-lgcc --sysroot=/home/dev/haiku/generated.loongarch64/cross-tools-loongarch64/sysroot --eh-frame-hdr -melf64loongarch -shared -no-undefined -X -o isl_test_cpp /home/dev/haiku/generated.loongarch64/cross-tools-loongarch64/lib64/gcc/loongarch64-unknown-haiku/13.3.0/crti.o /home/dev/haiku/generated.loongarch64/cross-tools-loongarch64/lib64/gcc/loongarch64-unknown-haiku/13.3.0/crtbeginS.o /home/dev/haiku/generated.loongarch64/cross-tools-loongarch64/sysroot/boot/system/develop/lib/start_dyn.o /home/dev/haiku/generated.loongarch64/cross-tools-loongarch64/sysroot/boot/system/develop/lib/init_term_dyn.o -L/home/dev/haiku/generated.loongarch64/cross-tools-loongarch64/lib64/gcc/loongarch64-unknown-haiku/13.3.0 -L/home/dev/haiku/generated.loongarch64/cross-tools-loongarch64/lib64/gcc/loongarch64-unknown-haiku/13.3.0/../../../../loongarch64-unknown-haiku/lib -L/home/dev/haiku/generated.loongarch64/cross-tools-loongarch64/sysroot/boot/system/develop/lib isl_test_cpp-isl_test_cpp.o ./.libs/libisl.a /home/dev/haiku/generated.loongarch64/objects/haiku/loongarch64/packaging/repositories/HaikuPortsCross-build/sys-devel/gcc_bootstrap/work-13.3.0_2025_01_13/sources/gcc_bootstrap-13.3.0_2025_01_13-obj/./gmp/.libs/libgmp.a -Bstatic -lstdc++ -Bdynamic -lgcc -lroot -lgcc /home/dev/haiku/generated.loongarch64/cross-tools-loongarch64/lib64/gcc/loongarch64-unknown-haiku/13.3.0/crtendS.o /home/dev/haiku/generated.loongarch64/cross-tools-loongarch64/lib64/gcc/loongarch64-unknown-haiku/13.3.0/crtn.o
gcc is trying to link objects in sysroot, but I can’t find them and this directory sysroot:
That’s also supposed to be generated by our build system. What target are you using? They should be built automatically under @bootstrap-raw.
After binutils updated to 2.43.1, I got more details when compiling isl_test_cpp:
/home/dev/haiku/generated.loongarch64/cross-tools-loongarch64/lib64/gcc/loongarch64-unknown-haiku/13.3.0/../../../../loongarch64-unknown-haiku/bin/ld: /home/dev/haiku/generated.loongarch64/cross-tools-loongarch64/lib64/gcc/loongarch64-unknown-haiku/13.3.0/../../../../loongarch64-unknown-haiku/lib/libstdc++.a(eh_globals.o):(.text.__cxa_get_globals_fast+0): relocation R_LARCH_TLS_LE_HI20 against `_ZZN12_GLOBAL__N_110get_globalEvE6global` can not be used when making a shared object; recompile with -fPIC
this is caused by libstdc+±v3, may be referring to TLS support.
Note that haiku use ELF ABI is a bit different from Linux. Every executables must be compiled with -shared flag (and PIC for everything except 32 bit x86). Statically linked and PIE executables are not supported. You may need to adjust default options in Haiku GCC for LoongArch.
After some fix with mno-relax and disable-tls. now I got gcc_bootstrap more progress, but some more errors faced:
n file included from ../haiku/headers/os/drivers/KernelExport.h:9,
                 from ../haiku/src/system/kernel/image.cpp:9:
In function 'int32 atomic_get_and_set(int32*, int32)',
    inlined from 'bool try_acquire_spinlock_inline(spinlock*)' at ../haiku/headers/private/kernel/smp.h:212:27,
    inlined from 'void acquire_spinlock_inline(spinlock*)' at ../haiku/headers/private/kernel/smp.h:219:33,
    inlined from 'void thread_suspend(bool)' at ../haiku/headers/private/kernel/thread.h:433:2,
    inlined from 'void notify_loading_app(status_t, bool)' at ../haiku/src/system/kernel/image.cpp:450:18:
../haiku/headers/os/support/SupportDefs.h:270:35: error: 'unsigned int __atomic_exchange_4(volatile void*, unsigned int, int)' writing 4 bytes into a region of size 0 overflows the destination [-Werror=stringop-overflow=]
  270 |         return __atomic_exchange_n(value, newValue, __ATOMIC_SEQ_CST);
It is a warning, not an error and it can be disabled.
