little followup, I wiped my previous Haiku partition on my macbook and installed this build. Looking through the syslog, I saw this and it seems to be recognized. still fails to load but does recognize the SPI device.
2026-09-21 02:18:08 KERN: PCI: device 9d2a: Sunrise Point-LP Serial IO SPI Controller #1
2026-09-21 02:18:08 KERN: PCI: info: Signal processing controller
2026-09-21 02:18:08 KERN: PCI: line_size 40, latency 00, header_type 80, BIST 00
2026-09-21 02:18:08 KERN: PCI: ROM base host 00000000, pci 00000000, size 00000000
2026-09-21 02:18:08 KERN: PCI: cardbus_CIS 00000000, subsystem_id 7270, subsystem_vendor_id 8086
2026-09-21 02:18:08 KERN: PCI: interrupt_line 17, interrupt_pin 04, min_grant 00, max_latency 00
2026-09-21 02:18:08 KERN: PCI: base reg 0: host 000000009282c000, pci 000000009282c000, size 00001000, flags 04 00
2026-09-21 02:18:08 KERN: PCI: base reg 2: host 00000000, pci 00000000, size 00000000, flags 00
2026-09-21 02:18:08 KERN: PCI: base reg 3: host 00000000, pci 00000000, size 00000000, flags 00
2026-09-21 02:18:08 KERN: PCI: base reg 4: host 00000000, pci 00000000, size 00000000, flags 00
2026-09-21 02:18:08 KERN: PCI: base reg 5: host 00000000, pci 00000000, size 00000000, flags 00
2026-09-21 02:18:08 KERN: PCI: Capabilities: PM, vendspec
2026-09-21 02:18:08 KERN: PCI: [dom 0, bus 0] bus 0, device 31, function 0: vendor 8086, device 9d4e, revision 21
2026-09-21 02:18:08 KERN: PCI: class_base 06, class_function 01, class_api 00
2026-09-21 02:18:08 KERN: PCI: vendor 8086: Intel Corporation
2026-09-21 02:18:08 KERN: PCI: device 9d4e: Sunrise Point LPC/eSPI Controller
2026-09-21 02:18:08 KERN: PCI: info: Bridge (ISA bridge)
2026-09-21 02:18:08 KERN: PCI: line_size 00, latency 00, header_type 80, BIST 00
2026-09-21 02:18:08 KERN: PCI: interrupt_line 00, interrupt_pin 00, min_grant 00, max_latency 00
2026-09-21 02:18:08 KERN: PCI: base reg 0: host 00000000, pci 00000000, size 00000000, flags 00
2026-09-21 02:18:08 KERN: PCI: base reg 1: host 00000000, pci 00000000, size 00000000, flags 00
2026-09-21 02:18:08 KERN: PCI: Capabilities: (not supported)
