Motherboard Compatibility Questions
I am looking to build a dedicated, low cost Haiku box. For the motherboard I am looking at the Gigabyte GA-H55M-S2H. This board uses the Intel H55 Express Chipset. It appears to have been released in 2010. I can not find any information on compatibility with this chipset. I would like to document the build and have it as a guide to building a low cost Haiku box.
Has anyone tried using it before?
Does anyone have a better recommendation?
Can I go with the AMD FX chipset?
I would like to keep all the component costs to less than $450 + tax & shipping.
Here is a link to the manufacture’s web site
CPU
Support for an Intel® Core™ i7 series processor/Intel® Core™ i5 series processor/ Intel® Core™ i3 series processor in the LGA1156 package
Chipset
Intel® H55 Express Chipset
Memory
  • 2 x 1.5V DDR3 DIMM sockets supporting up to 16 GB of system memory
  • Dual channel memory architecture
  • Support for DDR3 2200+/1800/1600/1333/1066/800 MHz memory modules
Onboard Graphics - Integrated in the Chipset:
  • 1 x D-Sub port
  • 1 x DVI-D port
  • 1 x HDMI port
Audio
  • Realtek ALC888B codec
  • High Definition Audio
  • 2/4/5.1/7.1-channel
  • Support for S/PDIF In/Out
  • Support for CD In
LAN 1 x RTL8111D chip (10/100/1000 Mbit) I/O Controller iTE IT8720 chip
Well I still have not found anything on the H55 chipset. It does appear that the AMD 880G chipset works with Hiaku. So now I am looking at the Gigabyte GA-880GM-D2H AMD 880G Motherboard - Micro ATX, Socket AM3, AM 880G Chipset, 1600MHz (O.C.), SATA 3.0 Gb/s, RAID, 8-CH Audio, Gigabit LAN.
Does anyone have any experience with this board/chipset?
Manufacturer product link
