Media Prefs: Audio Settings not functional?
Hi,
Got to start by saying I’m totally blown away with the progress the Haiku team has made. I’m installing daily (ish) builds now and I am just soooooo impressed and one very happy returnee to the BeOS camp :o)
I’m having a problem with the exuxki (Audigy) setup though, I can’t seem to select Audio Input, Output of Channel, so have no connection to the media server.
I was under the impression that this was possible now, is this correct? Can anyone offer any help/advice here?
Keep up the excellent work guys!! :o)
It’s possibly that there isn’t a driver, instal one from bebits altough emuxki should already be in the build.
I have tried to copy a driver sis7058(?) but when the media service prefs restart I doesn’t find them, is it not ready yet?
nutela wrote:
It's possibly that there isn't a driver, instal one from bebits altough emuxki should already be in the build.
There was some dependencies missing from the Haiku install that were required for the emuxki driver to work.
See http://www.haiku-os.org/bugzilla/show_bug.cgi?id=391 for more info… it is now working - and my SB Live produces sound in Haiku!
Hmmm…the Haiku-multi_audio add-on installs ok. On top of that I’m trying to load the Haiku-emuxki driver.
Nothing is available to select in the Audio Settings panel for default Audio Input or Output. I’m confused! :oops:
I thought the emuxki was a replacement driver for the Audigy line of soundcards.
I can get audio working if I install the Audigy_0.2 pkg from bebits. No problems…but that’s not what I want to test.
Since my first post (which was a separate Haiku partition), I have reverted to a single R5.0.3 install.
Should the multi audio add-on and the emuxki be R5 compatible? Tell me if I’m doing something wrong :?
Ta
El-Al
El-Al wrote:
Hmmm...the Haiku-multi_audio add-on installs ok. On top of that I'm trying to load the Haiku-emuxki driver.
Ta
El-Al
Unfortunately, I haven’t tried the Haiku driver under R5 yet - my SBLive worked fine with BeOS Max 3.1 already - so I didn’t mess with it.
I may get a chance soon to test it out for myself - and I’ll let you know if I do.
