Makehdimage ....... build failed svn checkout 14334
Ok don’t everybody run … but a newbe here … :shock:
I was trying to do a makehdimage … but the build failed … this is the error that I get …
Link objects/x86.release.haiku/tests/add-ons/kernel/file_systems/bfs/bfs_shell/bfs_shell
Chmod1 objects/x86.release.haiku/tests/add-ons/kernel/file_systems/bfs/bfs_shell/bfs_shell
SetType objects/x86.release.haiku/tests/add-ons/kernel/file_systems/bfs/bfs_shell/bfs_shell
MimeSet objects/x86.release.haiku/tests/add-ons/kernel/file_systems/bfs/bfs_shell/bfs_shell
SetVersion objects/x86.release.haiku/tests/add-ons/kernel/file_systems/bfs/bfs_shell/bfs_shell
…updated 1 target(s)…
Link objects/x86.release.haiku/tests/add-ons/kernel/file_systems/fs_shell/fs_shell_command
gcc: objects/x86.release.haiku/tests/add-ons/kernel/file_systems/fs_shell/fs_shell_command.o: No such file or directory
gcc: objects/x86.release.haiku/tests/add-ons/kernel/file_systems/fs_shell/fs_shell_command_beos.o: No such file or directory
gcc: No input files
    gcc  -o "objects/x86.release.haiku/tests/add-ons/kernel/file_systems/fs_shell/fs_shell_command"  "objects/x86.release.haiku/tests/add-ons/kernel/file_systems/fs_shell/fs_shell_command.o" "objects/x86.release.haiku/tests/add-ons/kernel/file_systems/fs_shell/fs_shell_command_beos.o"   ;
…failed Link objects/x86.release.haiku/tests/add-ons/kernel/file_systems/fs_shell/fs_shell_command …
…failed updating 1 target(s)…
*** Build failed!
Hope someone can help … I tried looking but couldn’t find the cause…
Thank You…
ZZ
cd to src/tests/add-ons/kernel/file_systems/bfs/bfs_shell and jam there, then redo the makehdimage command.
Thank You … MYOB
That worked
ZZ
