I have an old Intel 2013 MacBook Pro. Currently running Ubuntu 26.04 LTS, so I know it takes other operating systems just fine. I’ve made a live USB from the haiku-r1beta6-x86_64-anyboot iso with Balena Etcher. After selecting the USB as the boot drive, the boot screen with the Haiku logo and 7 icons shows up, but it just halts there. None of the icons light up. I’ve tried to use SHIFT or SPACEBAR as specified in the Bootloader manual but it stays frozen on the boot screen. I’ve tried Apacer USB 3.0 and Kingston USB 2.0 drives with the same result. Need help fixing this.
do you have rEFInd installed?
+1. Booting my Mac Pro from that era via refind works fine.
I installed rEFInd: sudo apt install refind. I restarted the computer but now it boots to a blank screen. I restarted again and accessed the macOS bootloader by holding option. I was able to get back into Ubuntu that way.
I checked that rEFInd was first in the boot order:
> sudo refind-mkdefault
eEFInd is already the first entry
No changes saved.
I don’t know if it helps but here is the contents of /boot/refind_linux.conf:
"Boot with standard options" "root=/dev/mapper/ubuntu--vg-ubuntu--lv ro quiet splash"
"Boot to single-user mode" "root=/dev/mapper/ubuntu--vg-ubuntu--lv ro quiet splash single"
"Boot with minimal options" "ro root=/dev/mapper/ubuntu--vg-ubuntu--lv"
I’ve been looking around for solutions but haven’t made it any further.
Installing Haiku on an older MacBook is highly challenging, as conflicts with the Apple firmware occur right from the boot-stage screen configuration. While a patch is available, Haiku’s policy prohibits merging any code generated by AI agents into its upstream. Consequently, I submitted the patch as a pull request to the RenkuOS project, where it has now been successfully merged.
For more details, please visit https://renkuos.org/.
shes asking you: use an ai assisted version of haiku that the developers dont approve of.
have you created an efi/esp partition when installing haiku?
I haven’t gotten to the install step yet, because I can’t boot from the live USB. Going back over my notes when I installed the rEFInd package in Ubuntu (on the same MacBook I’m trying to install Haiku on) there was a dialogue where it asked to install rEFInd to the EFI System Partition (ESP). I looked to see if this MacBook had an ESP with rEFInd installed somewhere and it looks like it does:
> tree boot/efi/EFI/refind/
├── BOOT.CSV
├── drivers_x64
│ └── ext4_x64.efi
├── icons
├── keys
├── refind.conf
└── refind_x64.efi
I assumed booting to the blank screen was a graphical issue so I tried to force rEFInd to use textmode by making the following settings in /boot/efi/EFI/refind/refind.conf:
textonly
textmode 2
resolution 1024 768
None of that had any effect. The computer still boots to a blank screen. So I’ve switched them off.
if it is still not working, then it may be a usb problem. try using another usb.
you can also see the page for refind at The rEFInd Boot Manager . honestly im not sure where to go from here so i suggest you ask a developer (like humdingerb) by pinging them with @
you can also ask others who use refind. @begasus @kim1963 dualboot with windows 11 so i think they should be able to help you more.
(sorry for the ping)
Not using refind here, good old F9 on boot to select. ![]()
this possible on macs?
I don’t know, I don’t own a Mac.
still, might be worth a try to use f9/f12/del keys when booting.
On a Mac it’s not F9 but holding the Alt key while booting.
I find it quite difficult to find the right time to press the key down so that it reacts to it,however.
So I can hold the option key when the Apple chime sounds after power up, and that will take me to the Apple mac boot loader. I can see the Haiku USB there. When I select it I get the Haiku Boot Screen. However it just hangs there. None of the icons light up and neither the shift nor space keys work. That’s my original problem.
I tried installing rEFInd to get around this problem. I installed it successfully but when I reboot the MacBook it never arrives at the rEFInd boot menu. It just halts on a blank screen.
So I’ve got two problems now:
- My Haiku live USB hangs on booting
- The MacBook won’t boot to rEFInd
I can still get into the Mac boot loader and get to Ubuntu.
Since rEFInd was not working after installing it on my MacBook, I tried to install it on a USB and see if it would load from that.
sudo mkfs.vfat /dev/sdb
sudo refind-install --usedefault /dev/sdb
I restarted the computer and held down option to access the Mac bootloader. I selected the USB. The computer stayed frozen at the bootloader menu. rEFInd did not load.
At this point I don’t think rEFInd is going to work on this computer so I’m going to uninstall it and try different options to get Haiku working.
Some success. With all of the live USB sticks I’ve made there are three options at the macOS boot menu:
- EFI Boot that is obviously the internal SSD
- A Windows drive
- An EFI boot that is a USB with a leaf logo
I’ve always been selecting option 3, assuming that the leaf was some Haiku logo. That has always shown the Haiku boot load screen but has always remained frozen.
This time I selected option 2 ‘Windows’ and now I am at the ‘Welcome to Haiku!’ menu. I have been writing the USB sticks with Balena Etcher following the Haiku guides. I’ve got no idea why the option is labeled ‘Windows’ but I guess is that it’s down to how the macOS bootloader reads the USB.
Anyway I’m going to try to install Haiku now.
I managed to get Haiku installed. It’s not getting past the boot loading screen however and neither the SHIFT nor SPACE keys will work.
My original problem with booting from the USB is solved so I’m considering this thread closed. Thanks for all the help.
