Libxtst help?
hi
i’m trying to build a QT Package giving me an error "libxtst can not be found.
is there such a lib in/for haiku?
if it’s implemented in a system lib, how do i link to it,so i can build my package?
anybody???
Perhaps you might check over at the TiltOS website.
  • http://tiltos.com/drupal/
I think they specialize in using QT programs on Haiku. So there may be more information on it there. Hope this helps.
Since Haiku doesn’t use X window system using libraries for X is not going to work. You probably need to edit the build-script, and if they really use X functionality the code itself. Remember doing a port properly is a lot more than just getting it to build.
