Interest in Reviving PowerPC Support – Testing on iBook G3 and PowerMac G5
Still a way off. Last few weeks it got closer, but it still fails to boot. It also emulates quite old hardware so though it might be okay, it probably is less useful than qemu. It is really targeted at classic old world hardware.
Hi everyone,
I recently tried to build Haiku for PowerPC on a Debian 12 VM, with all the toolchains properly set up (following the wiki instructions and some forum threads).
The result? The process fails miserably before even getting to the actual build stage. Forget booting anything – I couldn’t even generate a working ISO.
That said, at least I gave it a shot.
Are there any updates on the PPC port? Has anyone made any progress in the past few months?
Would be great to know if there’s still some activity going on, or if we’re officially in deep freeze.
Cheers!
I was a bit busy with some other stuff in the last weeks. I’ve implemented a very simple dhcp client that allows netbooting Haiku with a local copy of the bootloader, but that is not upstreamed yet, as I had some university-related stuff to do. I’ll try to have a look at getting the kernel to actually load, however, I at least don’t know how much time I’ll have in the coming months.
kind regards,
zeldakatze
Thanks for the update, and congrats on the DHCP client – even if it’s not upstreamed yet, it’s great to know someone is still working on PPC support.
Totally understand the university commitments. Your efforts are very much appreciated, and we’ll be looking forward to any future progress whenever time allows.
Good luck with your studies!
At the moment you probably need to do a “bootstrap” build, which is a bit more complicated and fragile than the normal build.
So, yes, we’re really not at the stage where you can build it just to try if it will run. The time is more for investigating buildsystem issues, updating documentation on the build process, and the like.
hello,
okay, some progress: In the upstream build, the kernel fails to load since the binary is missing a seperate data LOAD header. By manually patching the kernel’s linker script to have seperated text and data LOAD segments like @Yn0ga did, the kernel actually loads. By disabling the boot splash,
you can see that the kernel starts and then goes into kdebug. However, the kernel runs without any modules, since they only have one LOAD header and can thus not be loaded. I’m quite confused as to why this happens and also why this only happens on ppc. I thought that by default ld creates multiple LOAD entries and on every other architecture, this seems to be the case.
Does anyone have an idea, why this happens? I could not find a default ldscript or similar and there don’t seem to be any big differences between ppc and other architectures. It looks like it has something to do with the toolchain itself, so I’ll check that aswell once I find some time.
kind regards,
zeldakatze
I just had a quick glipse at these tickets and they do not seem to really have to do with these kind of linkage problems. Especially since you can see the haiku kernel being loaded in Ticket 1048 (it gets to the kernel debugger) so the linking must have worked properly at some point (unless the way the bootloader reads elfs has changed). I might have a look if there is some kind of regression in the buildtools.
Another victim of marcoapc posting unrelated links in discussions. He does that all the time. I recommend ignoring him and not wasting your time.
Anyway, kernel add-ons are linked using the KernelAddon rule defined in build/jam/KernelRules. There is indeed no ldscript there, that shouldn’t be needed. The main control will be through HAIKU_KERNEL_ADDON_LINKFLAGS which can be tweaked as needed in build/jam/ArchitectureRules. Currently nothing special is set for powerpc, but -z noseparate-code is set for clang (this would create a single load segment, I think).
It looks like this option is not enabled by default in ld unless building for linux x86 (as seen in binutils/ld/configure.tgt line 1179), so it seems to be a good idea to enable it explicitly for all our kernel things. The alternative would be to change the kernel elf loader so it can handle single-load executables.
I think the option may not be needed if the default linker script does not put the data and code right next to each other. In that case, ld will generate two PT_LOAD sections, not because of separating code and data, but because the two things are already at separate addresses anyway. So maybe that makes it work by accident on other architectures, but on ppc it happens that code and data are next to each other and end up in the same section?
What victim?
The purpose of a forum is to present ideas and seek solutions. The solution does not always come from the answer, but rather from the debate of ideas. I believe that no one who is technical in their conception can present ideas. If they are technical, they cannot make mistakes.
Learn to respect others regardless of their successes and mistakes, be humble or keep quiet.
You are wasting people time by sending them in wrong directions, repeatedly and despite many complaints and requests to stop.
Either you do not realize how much time people will spend researching the links you posted. trying to understand them, and finding out that it didn’t help them.
Or, you are doing this intentionally to waste people’s time.
If you want to contribute useful things, you have to spend considerably more time yourself understanding the problems and finding actually related links, explain why they are related, and why you think they can bring a solution. Your pasting of random links put that effort on the person who reads your message. As such, they are victim, since you send them on wrong directions, and waste their time. Please stop doing that, as you have been asked to many times already.
You have been told time again, and again, and again to not post unrelated links. You have already been suspended once for this.
I’m suspending you for 4 months. If you do this again you will be permanently suspended from the forums.
It would make sense to have seperate LOAD headers, as you can set different access permissions (RW on DATA, RE on code). On Debian/ppc, gcc seperates the headers like that by default aswell. I’ll look at the toolchain and try to find out the differences there
The bootloader (and possibly the kernel ELF loader also) only supports ELFs with one TEXT and one DATA section; the TEXT section is expected to be RX and the data RW. By default, Clang + LLD create multiple of each, so we have to specify some -z flags to get back the old behavior for the kernel and addons. (runtime_loader properly supports this so we don’t need to set it for userland binaries.)
Since i recently stumbled upon this in relation to this, can someone explain what the “linkhack.so” is used for? It looks to just be an empty file. Why is this required?
A bit of digging reveals the commit that intrduced this in NewOS back in 2001: https://github.com/travisg/newos/commit/8319f2b02bc9b77720cf2d9922233b4421f8df9f
The commit message explains it briefly, we want the kernel to be exported as a shared library with a dynamic section, so that we can link kernel add-ons against it. Linking against a .so did the job back then. There may be cleaner way to achieve it.
The comment in the makefile was lost when migrating to jam, I guess it could be rescued and reintroduced
The NewOS kernel has been supporting ppc for a long time. What made Haiku has a much slower progress than NewOS in porting to ppc?
Lack of interest from the developers. Apple stopped making PowerPC hardware in 2005, at which point Haiku was in early development. So people have been more interested in newer systems and focused on x86.
There were some effort by Bonefish (on a mac mini) and later by mmu_man (on a Sam440 board), but one developer having a look into it from time to time is not enough to keep things progressing, you can only fix the problems that accumulated since last time you looked into it.
Lately there seem to be a bit more people hacking on it and making decent progress :slight_smile:
I tried to build @minimum-raw for ppc, It has some problems compiling gcc_syslibs 8 or something.
I tried using gcc_syslibs13 instead. But it is not available for ppc. How can i get this available? I have the ppc targeting toolchain already build
Do a bootstrap build. As long as the system is not bootstrapped and the prebuilt packages updated, normal builds won’t work.
hello again,
I’ve had a look at the linking issue on powerpc which seems to be a regression between
btrev43147 ( gcc: Change ARM typeinfo behavior to match other architectures.) and btrev43149 (binutils: Fix powerpc gas target for Haiku) (The regression very likely happend with btrev43148 which imported binutils 2.38).
Running objdump -x on a test executable compiled with btrev43147 yields
objdump for btrev43147
helloworld:     file format elf32-powerpc
helloworld
architecture: powerpc:common, flags 0x00000150:
HAS_SYMS, DYNAMIC, D_PAGED
start address 0x00000000
Program Header:
    LOAD off    0x00000000 vaddr 0x00000000 paddr 0x00000000 align 2**12
         filesz 0x000001e4 memsz 0x000001e4 flags r-x
    LOAD off    0x000001e4 vaddr 0x000011e4 paddr 0x000011e4 align 2**12
         filesz 0x00000068 memsz 0x00000068 flags rwx
 DYNAMIC off    0x000001e4 vaddr 0x000011e4 paddr 0x000011e4 align 2**2
         filesz 0x00000058 memsz 0x00000058 flags rw-
EH_FRAME off    0x00000198 vaddr 0x00000198 paddr 0x00000198 align 2**2
         filesz 0x00000014 memsz 0x00000014 flags r--
Dynamic Section:
  HASH                 0x000000b4
  STRTAB               0x00000154
  SYMTAB               0x000000e4
  STRSZ                0x0000001f
  SYMENT               0x00000010
Sections:
Idx Name          Size      VMA       LMA       File off  Algn
  0 .hash         00000030  000000b4  000000b4  000000b4  2**2
                  CONTENTS, ALLOC, LOAD, READONLY, DATA
  1 .dynsym       00000070  000000e4  000000e4  000000e4  2**2
  2 .dynstr       0000001f  00000154  00000154  00000154  2**0
  3 .text         00000024  00000174  00000174  00000174  2**2
                  CONTENTS, ALLOC, LOAD, READONLY, CODE
  4 .eh_frame_hdr 00000014  00000198  00000198  00000198  2**2
  5 .eh_frame     00000038  000001ac  000001ac  000001ac  2**2
  6 .dynamic      00000058  000011e4  000011e4  000001e4  2**2
                  CONTENTS, ALLOC, LOAD, DATA
  7 .got          00000010  0000123c  0000123c  0000023c  2**2
                  CONTENTS, ALLOC, LOAD, CODE
  8 .comment      00000011  00000000  00000000  0000024c  2**0
                  CONTENTS, READONLY
SYMBOL TABLE:
000000b4 l    d  .hash	00000000 .hash
000000e4 l    d  .dynsym	00000000 .dynsym
00000154 l    d  .dynstr	00000000 .dynstr
00000174 l    d  .text	00000000 .text
00000198 l    d  .eh_frame_hdr	00000000 .eh_frame_hdr
000001ac l    d  .eh_frame	00000000 .eh_frame
000011e4 l    d  .dynamic	00000000 .dynamic
0000123c l    d  .got	00000000 .got
00000000 l    d  .comment	00000000 .comment
00000000 l    df *ABS*	00000000 helloworld.c
000011e4 l     O .dynamic	00000000 _DYNAMIC
00000198 l       .eh_fram]e_hdr	00000000 __GNU_EH_FRAME_HDR
00001240 l     O .got	00000000 _GLOBAL_OFFSET_TABLE_
0000124c g       .got	00000000 __end
0000124c g       .got	00000000 __bss_start
00000174 g     F .text	00000024 main
0000124c g       .got	00000000 _edata
0000124c g       .got	00000000 _end
Whilst running objdump -x on the binary compiled with btrev43149
objdump for btrev43149
helloworld
Program Header:
    LOAD off    0x00000000 vaddr 0x00000000 paddr 0x00000000 align 2**16
         filesz 0x000011a8 memsz 0x000011a8 flags rwx
 DYNAMIC off    0x00001140 vaddr 0x00001140 paddr 0x00001140 align 2**2
EH_FRAME off    0x000000f4 vaddr 0x000000f4 paddr 0x000000f4 align 2**2
Dynamic Section:
  HASH                 0x00000094
  STRTAB               0x000000c8
  SYMTAB               0x000000a8
  STRSZ                0x00000006
  SYMENT               0x00000010
Sections:
  0 .hash         00000014  00000094  00000094  00000094  2**2
  1 .dynsym       00000020  000000a8  000000a8  000000a8  2**2
  2 .dynstr       00000006  000000c8  000000c8  000000c8  2**0
  3 .text         00000024  000000d0  000000d0  000000d0  2**2
  4 .eh_frame_hdr 00000014  000000f4  000000f4  000000f4  2**2
  5 .eh_frame     00000038  00000108  00000108  00000108  2**2
  6 .dynamic      00000058  00001140  00001140  00001140  2**2
  7 .got          00000010  00001198  00001198  00001198  2**2
  8 .comment      00000011  00000000  00000000  000011a8  2**0
                  CONTENTS, READONLY
SYMBOL TABLE:
00000094 l    d  .hash	00000000 .hash
000000a8 l    d  .dynsym	00000000 .dynsym
000000c8 l    d  .dynstr	00000000 .dynstr
000000d0 l    d  .text	00000000 .text
000000f4 l    d  .eh_frame_hdr	00000000 .eh_frame_hdr
00000108 l    d  .eh_frame	00000000 .eh_frame
00001140 l    d  .dynamic	00000000 .dynamic
00001198 l    d  .got	00000000 .got
00001140 l     O .dynamic	00000000 _DYNAMIC
000000f4 l       .eh_frame_hdr	00000000 __GNU_EH_FRAME_HDR
0000119c l     O .got	00000000 _GLOBAL_OFFSET_TABLE_
000000d0 g     F .text	00000024 main
(Note the missing second LOAD program header for data).
I’ll try to have a look at fixing it but did not yet have any luck fixing it. Maybe someone could have a look at that who has more knowledge about binutils than I do.
kind regards,
zeldakatze
