The problem with installing packages, Haiku hangs, does not write to logs
The problem is that the packages seem to be a lot
Can you explaine that do you have done, step by step?
Install QT5 in HaikuDepot…
Installing the package for the package - addiction, it’s on the withers
You sure nothing’s written to the syslog? That’s quite unsual, because the package_daemon logs pretty much everthing it does.
Are you using Haiku in a virtual machine? Is your network set up correctly?
Really?
Oh, sorry)), this is google translate here translate this text, i,m bad know english, sorry
In general there, so hangs on the packages, please help
Without more information, it’s difficult…
Maybe misconfigured network, not enough free space on the disk, filesystem corruption. The syslog should at least provide some clue.
I deleted the syslog, then started compiling Haiku, it also hung, then rebooted, the syslog did not appear, apparently the syslog can not tell anything, the network is configured fine, dhcp-lan
