I need haiku-inputkit compiled for R5. Where can I download it?
Usually, the R5 versions of Haiku components are distributed as “jam packages” on the Haiku Build Factory:
I see an inputkit package there. Hopefully Sikosis fixed the TARGET_PLATFORM=r5 issue by now (at one point, it was building all the packages for Haiku, not R5).
That said, I would be extremely careful applying this to your R5 system, as it may render it unusable. Make sure you have a boot CD, or some method to fix it if it doesn’t work right.
Thank you!
