Ah, yes. That is a known issue with haikuporter. You need to clean a work dir if you tried to build a recipe and then it was updated. You can do that with:
haikuporter vmware_addons --clean
Yeah. Now it builds and installs. Thanks! It was the first time I have ever used haikuporter.
Regarding the source file with the list of display modes, I donât know what are all those numbers:
{ { 210640, 1920, 1952, 2752, 2784, 1440, 1470, 1482, 1513, 0 }, B_RGB32_LITTLE, 1920, 1440, 0, 0, MODE_FLAGS }, /* 1920x1440@50Hz */
{ { 245600, 2048, 2080, 3008, 3040, 1536, 1568, 1581, 1613, 0 }, B_RGB32_LITTLE, 2048, 1536, 0, 0, MODE_FLAGS }, /* 2048x1536@50Hz */
{ { 319750, 3440, 3488, 3520, 3600, 1440, 1443, 1453, 1481, 0 }, B_RGB32_LITTLE, 3440, 1440, 0, 0, MODE_FLAGS }, /* 3440x1440@60Hz */
I looked through other files and did not find where display_mode is defined. Is it part of some Haiku specific API?
I wanted to try 3072x1920@60GHz with 32bit color.
I only remember that I had copied display mode for my laptop from this file:
Not sure how to generate a new record. Hopefully, somebody can chime in.
Maybe you can try one of those online modeline calculators? Like https://arachnoid.com/modelines/
Youâd want to pull display modes from Parallel or some Mac screen display tool for custom resolutions.
The display mode info is modeline info for HSync/VSync. Apple and other OEMs usually stick that info
in the laptop manuals (or tech docs).
Example only (this is NOT accurate for the new 2020 Mac Pro 13' or 16' laptops, not tested):
{ { 2XXXXX, 2560, 2752, 3024, 3488, 1440, 1443, 1448, 1493, 0 }, B_RGB32_LITTLE, 2560, 1440, 0, 0, MODE_FLAGS }, /* 2560x1440@60Hz */
{ { 2XXXXX, 2560, 2760, 3032, 3504, 1600, 1603, 1609, 1658, 0 }, B_RGB32_LITTLE, 2560, 1600, 0, 0, MODE_FLAGS }, /* 2560x1600@60Hz */
{ { 3XXXXX, 3072, 3312, 3648, 4224, 1920, 1923, 1929, 1989, 0 }, B_RGB32_LITTLE, 3072, 1920, 0, 0, MODE_FLAGS }, /* 3072x1920@60Hz */
{ { 3XXXXX, 3840, 4128, 4544, 5248, 1600, 1603, 1613, 1658, 0 }, B_RGB32_LITTLE, 3840, 1600, 0, 0, MODE_FLAGS }, /* 3840x1600@60Hz */
{ { 3XXXXX, 3840, 4160, 4576, 5312, 2160, 2163, 2168, 2237, 0 }, B_RGB32_LITTLE, 3840, 2160, 0, 0, MODE_FLAGS }, /* 3840x2160@60Hz */
No success until now, unfortunately. In Parallels I get a reasonable image quality by selecting a resolution (3584x2240) that is weirdly higher than the native one. It even allows for higher resolutions, but this one has worked fine for me, with nice crisp details.
In contrast, the best I am able to get in VMware Fusion is a somewhat blurry picture, which is sad because otherwise it is performing well enough (despite the fact that it also has no sound).
I think you can get those values by running screenmode -m in Haiku running in Parallels.
Well, I decided to quit on this one, after getting a discounted price for another year on Parallels. I was not able to make it work properly on VMware Fusion, but it would be great to have it one day.
Managed to get the native resolution on my laptop in VMWare Player by selecting âspecify monitor settingsâ and entering the native resolution in there, dropped the environment to 16b color, enabled sound by editing the vmx file in Windows, works fine in full-screen now (both 32bit and 64bit).
PS. @BiPolar those guys produce a LOT of noice!
Currently, I have managed to get haiku to Work in full resolution in VMware but I am out of luck in Parallels.
If your hears arenât bleeding⊠it ainât Metal enough!
\m/
\m/
(for the more melodic-inclined⊠try Carcassâ âHeartworkâ or âSwansongâ albums)
Can you share your .vmx file for that one (or just part of it related to svga)? Unfortunately VMware Fusion doesnât allow to configure the resolution.
No idea anymore, it has been a while since I launched Haiku in a VM (aside from these days in qemu on Haiku itself). Sorry ![]()
No worries, Iâve realised you had 1920x1080, while Iâm trying to enable 2880x1800 (physical display resolution on my Retina laptop), without luck though. I have Haiku running directly on that MacBook with the specified resolution, and Iâm trying to achieve the same in the VMWare Fusion.
