Howdy!
I encountered two warnings during the make process. Are these warnings detrimental to using the application?
Here is the output:
~> cd /boot/home/Development/id3ren-master
~/Development/id3ren-master> make install
make -C src install
make[1]: Entering directory ‘/boot/home/Development/id3ren-master/src’
gcc -s -O2 -Wall -o id3ren id3ren.c id3tag.c id3file.c id3misc.c
id3ren.c: In function ‘main’:
id3ren.c:833:5: warning: ‘strncpy’ specified bound depends on the length of the source argument [-Wstringop-overflow=]
strncpy(program_path, argv[0], ((strlen(argv[0]) - strlen(p)) - 1));
id3ren.c:833:38: note: length computed here
id3misc.c: In function ‘print_error’:
id3misc.c:125:23: warning: ‘%s’ directive writing up to 1023 bytes into a region of size 1022 [-Wformat-overflow=]
sprintf(buf, “%s: %s: %s\n”, program_name, buf, strerror(errno));
id3misc.c:125:5: note: ‘sprintf’ output 6 or more bytes (assuming 1029) into a destination of size 1024
install -D -s -m 755 id3ren /usr/bin/id3ren
install: cannot create regular file ‘/usr/bin/id3ren’: Invalid Argument
Makefile:23: recipe for target ‘install’ failed
make[1]: *** [install] Error 1
make[1]: Leaving directory ‘/boot/home/Development/id3ren-master/src’
Makefile:8: recipe for target ‘install’ failed
make: *** [install] Error 2
I know the fatal errors near the end is due to new virtual directory hierarchy in Haiku. No problem since the new application was in the ‘src’ directory.
I executed the new application and it seems to be working where I added new ID3 tags to four audio files. I confirmed and verified the tags were updated into the audio files.
Not sure what these warning are about. Can one of the developers explain what I am seeing in this output?
Thanks in advance!
