I think many of software in Haiku is outdated
Come on, it is 2025 now,and I am still translating something like “MBR”,“Modem”.
No Fcitx,zip and unzip use 2 software.
we need to port more from Linux like system,and some more original software.
I’m looking forward to your patches
No I am just a translator.
Nope - don’t … must not do those things - there are thousands already.
There’s plenty distros for those apps.
More drivers and system components and their fix, thank you !
Even GhostBSD have those apps,I don’t think that is a problem when you have more choice.And the most problem is Fcitx,we Chinese need a better input method then BeCJK,I think those Korean and Japanese will accept me.
Not sure fcitx would build and work on Haiku.
Anyway, only someone speaking such language can make it happen.
Someone else could try to build it but without possibility to do real testing, they wouldn’t know if it works correctly or not.
If you find the seperation between Zipomatic and Expander annoying, just use Beezer
More drivers , or more polished drivers with the already ones we have(basically radeon_hd in pair with the radeon linux driver at least on my computer with an old R9 works correctly).
