Hrev49811 and hrev49813
Update hrev49803 to hrev49811
1.
Encountered problems:
problem 1: nothing provides haiku_x86>=r1~alpha4_pm_hrev77777-1 needed by haikuwebkit_x86-1.5.0-1
solution 1:
- keep haikuwebkit_x86-1.4.13-1 from excluded repository
Please select a solution, skip the problem for now or quit.
select [1/s/q]: s
problem 2: nothing provides haiku_x86>=r1~alpha4_pm_hrev77777-1 needed by haikuwebkit_x86-1.5.0-1
solution 1:
- keep webpositive_x86-r1~alpha4_pm_hrev49803-1 from excluded repository
select [1/s/q]:
  1. KeymapSwitcher - not work !
The update issue should be fixed in hrev49814 which provides haikuwebkit-1.5.0-3 with the correct requires.
KeymapSwitcher problem is fixed in hrev49819.
OK !
