Hi,
I have compiled an application that requires a user file to function properly. so I want to create the application in the non-packaged directory so that the user can put the file in the application folder. But the problem is that the HPKG that I create has never put the application in the non-packaged directory. I thought it was possible.
Non packaged is only for installing by hand, zip or old pkg file (beos).
Settings should ever place under /boot/home/config/settings/programname
User files to save other data like highscore… can be installed by post-install script
User files, files the user create are place into the home directory
http://besly.de/index.php/en/package-system/haiku-package-tips-and-tricks
If you need the file in the app folder copy them to the home folder… and create a link into you app folder.
Take a look at hpkgcreator here you can do this
Hi thanks,
I don’t find the options for create a shorcut of the file in the app folder via HPKG creator, this file doesn’t not exist in startup. (it’s a file from a certain CD that the user must have). Maybe via post install to do it…
I have try to put the link directly into the Temp folder of HPKG creator but that remove the link after reload the project…Go find a way to done it…
-------------Reedit-----------
Ok it’s done! I can send it to you?
If you want to see i solve this install diamondgirl from our repo and importieren it into hpkg. Then open the package folder (menu option in hpkgcreator) and take a look at the zip file and postinstall Script
Here it’s done, thanks.
