How to use LaunchBox?
i want to use launchbox to have easy access to applications. unfortunately the documentation both online and offline are very bare bones and do not tell how to add applications. so how do i put applicatiions in launchbox?
Just add a button and drop there what you want
is there any way to hide it from the deskbar
Yes, something like this should work:
cp /system/apps/LaunchBox ~/config/non-packaged/bin/
FileTypes ~/config/non-packaged/bin/LaunchBox
# tick Background app
ln -s /boot/home/config/non-packaged/bin/LaunchBox /boot/home/config/settings/boot/launch
Does having a copy of the app with the same signature in non-packaged allow the latter to be executed over the one present in packagefs? Or is it necessary to blacklist the original one?
this doesnt work in terminal and when i try in tracker it crashes it
Yeah, no need to blacklist it.
What exactly doesn’t work? Do you have a crash report?
no, i fixed the issue. i typed a command wrong and forgot to tick background app in filetype but now it is working. sorry
At first launch, it should show a preloaded launch bar. From that you have a contextual menu on any item of the launch bar:
  • you can create a new launch bar
  • you can “clear” the button and then drag and drop a new app icon into it
  • you can add/delete buttons
  • change the icons size, the look and feel of the launch bar window(s)
