How to place an image (JPG,, GIF, etc.) with YAB?
You can look into all my yab apps and games. The source always in the program folder under/boot/system/apps/nameofprogram
Hi,
Yes I doing this. This is helpfull Thanks.
But I don’t find the Application Message for the resize button?
I want to place something in case of it.
https://besly.de/index.php/en/development/yab/yab-and-the-layout-command
All changes are majeable with the layout command, but i does not know if this is possible with buttons
I have try with the layout command before but there where some bug (a View stay in the same position when I resize the window) I had put a layout “all” and layout “bottom,right,left”) but and that make a grey square in my main text edit box when I resized the window.
For now I finaly found a “solution” by make a split in the app but that can be helpfull if I encounter same bug again in other app.
Can you send me a cut of your source or screenshot, so i can check for a solution.
The layout option need to set for all things on the window.
It’s upgraded now
The solution is done by an other way but here is all the code(for now it can compile one file) but I advice the compilator put a file in /boot/home/buil for now:
window open 50, 50 to 710,530, "View", "TextEditor"
layout "top,bottom,right,left", "View"
window set "View", "minimumto",640,480
menu "File","Open","O","View"
menu "File","New","N","View"
menu "File","Save","S","View"
menu "File","Save As...","Z","View"
menu "File","Quit","Q","View"
menu "Run","Compile","C","View"
menu "Run","Run","R","View"
menu "Options","Linking","L","View"
menu"Help","About","A","View"
h = window get "View", "height"
w = window get "View", "width"
LinkLib$=""
current_path$="/boot/home"
current_file$=""
//Splitview crée 2 vues ajustables dans View ici
splitview 0,25 to 660,465, "Split", false, false, "View"
tooltip "Split", "SPLITVIEW"
textedit 0,0 to 660,h-150, TextEd$, 3, "Split1"
LISTBOX 0,0 to w,100, Log$,3, "Split2"
inloop = true
while(inloop)
	Option$="countlines"
	LineCount=TEXTEDIT GET TextEd$,Option$
	Option$ = "currentline"
	LineNumber = TEXTEDIT GET TextEd$, Option$
	Update()
	msg$=message$
	switch msg$
	case "View:_QuitRequested|"
		inloop = false
	break
	case "View:File:Quit|"
		inloop = false
	break
	case "View:File:Open|"
		filename$ = ""
		filename$ = filepanel "load-file", "Open File", current_path$,""
		if(not(filename$=""))then
			//Clear the text Edit box
			TEXTEDIT CLEAR TextEd$
			FileDir()
			//Open the file
			open filename$ for reading as #1
			while(!eof(1))
				//Read a line and stock it in newline
				line input #1 newline$
				//Add the new line + \n in Text box
				textedit add TextEd$, newline$ + "\n"
			wend
			//close file
			close #1
			//Place the cursor to line 1 when finished loading the file
			textedit set TextEd$, "gotoline", 1
		endif
		break
	case "View:File:Save|"
		SaveFile()
	break
	case "View:File:Save As...|"
		SaveFileAs()
	break
	case "View:Run:Compile|"
		LISTBOX CLEAR Log$
		SaveFile()
		print ("gcc "+filename$+" -o /boot/home/build "+LinkLib$)
		if(LinkLib$="")then
			if(system("gcc "+filename$+" -o /boot/home/build 2> /boot/home/log.txt")=0)then
			alert "Compilation successfull","Ok","Message"
			endif
		elseif(system("gcc "+filename$+" -o /boot/home/build "+LinkLib$+" 2> /boot/home/log.txt")=0)then
			alert "Compilation successfull with lib","Ok","Message"
		endif
		open "/boot/home/log.txt" for reading as #1
		while(!eof(1))
			line input #1newline$
			LISTBOX ADD Log$, newline$
		wend
		close #1
	break
	case "View:File:New|"
		NewFile()
	break
	case "View:Run:Run|"
		system("Terminal /boot/home/build")
	break
	case "View:Options:Linking|"
		Linking()
	break
	case "View:Help:About|"
		alert "Developed by Kitsune.", "Ok", "About"
	break
	end switch
wend
window close "View"
Exit
sub Update()
	draw flush "View"
	draw text 10,h-3,"Line: "+str$(LineNumber)+"/"+str$(LineCount), "View"
	return
end sub
sub SaveFile()
	if(current_file$="")then
		SaveFileAs()
	elseif(current_path$="")then
		SaveFileAs()
	else
		file2save$=textedit get$ TextEd$
		filename$=current_path$+current_file$
		open filename$ for writing as #1
		print #1 file2save$
		close #1
		print ("Saved File at "+filename$)
	endif
end sub
sub SaveFileAs()
	file2save$=""
	filename$=""
	file2save$ = textedit get$ TextEd$
	if file2save$ <> "" then
		filename$ = filepanel "save-file", "Save File As ...", current_path$,current_file$
		if filename$= "" return
		FileDir()
		print #1 file2save$
		close #1
	endif
end sub
sub FileDir()
			//RécupÚre le nom du fichier courant
			current_file$=system$("basename "+filename$)
			//Supprimer le caractĂšre espace ou "\n" en fin de ligne"
			current_file$=rtrim$(current_file$)
			FileLenght=len(current_file$)
			cpt=0
			spacetxt$=""
			while(cpt<FileLenght)
				spacetxt$=spacetxt$+" "
				cpt=cpt+1
			wend
			print current_path$
			current_path$=filename$
			right$(current_path$,FileLenght)=spacetxt$
			current_path$=rtrim$(current_path$)
			print current_path$
			print current_file$
			print str$(FileLenght)
end sub
sub NewFile()
	selected = alert "Would you like to continue to create a new file? This will erase the current content.", "Yes", "No","Save the current File before","info"
	if(selected=1)then
		LISTBOX CLEAR Log$
		current_file$=""
	elseif(selected=3)then
		SaveFile()
		LISTBOX CLEAR Log$
		current_file$=""
	endif
end sub
//Option menu
sub Linking()
	window open 150, 150 to 640,230, "Linking", "Link library"
	option set "Linking", "Focus", true
	TEXTCONTROL 10,10 TO 480,20, "InputLib", "", LinkLib$, "Linking"
	BUTTON 10,40 TO 80,70, "LinkButOk", "Ok", "Linking"
	quitting=0
	while(not quitting)
		m$ =message$
		if(m$ = "LinkButOk|")then
			LinkLib$ = TEXTCONTROL GET$ "InputLib"
			quitting =true
		endif
		if(instr(m$, "_QuitRequested")) quitting = true
	wend
	print LinkLib$
	window close "Linking"
end sub
Here something to play around, i does not get two buttons under each over to change in the same direction.
WINDOW OPEN 200,200 TO 600,600, "MyWindow", "Test"
	DRAW SET "BGColor", 10,10,100, "MyWindow"
//First 2 Buttons
LAYOUT "Left, Top, Right", "MyWindow"
	BUTTON 10,10 TO 200,40, "BT:1", "Button 1", "MyWindow"
	BUTTON 10,50 TO 200,80, "BT:2", "Button 2", "MyWindow"
//Second 2 Buttons
LAYOUT "Left, Bottom, Right", "MyWindow"
	BUTTON 10,100 TO 200,130, "BT:3", "Button 3", "MyWindow"
	BUTTON 10,140 TO 200,170, "BT:4", "Button 4", "MyWindow"
//Third 2 Buttons
LAYOUT "Left, Botto, Top, Right", "MyWindow"
	VIEW 10,200 TO 210,240, "View1", "MyWindow"
		DRAW SET "BGColor", 10,10,100, "View1"
		//LAYOUT "Left, Top, Bottom, Right", "View1"
			BUTTON 0,0 TO 200,30, "BT:5", "Button 5", "View1"
	VIEW 10,250 TO 210,290, "View2", "MyWindow"
		DRAW SET "BGColor", 200,10,200, "View1"
		//LAYOUT "Left, Top, Bottom, Right", "View2"
			BUTTON 0,0 TO 200,30, "BT:6", "Button 6", "View2"
//Main Loop
dim part$(1)
inloop = true
while(inloop)
        //General Messages
        msg$ = message$
        if (split(msg$, part$(), ":|") > 2) then
                PartOne$=part$(1)
                PartTwo$ = part$(2)
                PartThree$ = part$(3)
        fi
        if (split(msg$, part$(), ":|") > 3) then
                PartFour$ = part$(4)
        fi
        if (split(msg$, part$(), ":|") > 4) then
                PartFife$ = part$(5)
        fi
        if (msg$ <> "") print msg$
        switch (msg$)
        case "MyWindow:_QuitRequested|"
		WINDOW CLOSE "MyWindow"
		break
          default:
        break
        end switch
        wait 0.05
        if(window count<1) inloop = false
        sleep 0.05
wend
I have this error at first line but don’t know why: 0xff
that was the " "
try again, i have pasted the source as quote, so he change the " sign to a not current on
Hi,
I try to dynamically make some Stackview for View new open file. The idee is like the YabIDE file list that open document in a TextEdit but I don’t find the method for make it.
YabIDE have a source code somewhere?
Ok I find it here:
Yab IDE Source
Thanks
Ok apparently YabIDE can open maximum 20 files by default and a comment of dynamically implement Stackview is in the code source. So this is the way.
It is not so complicated. But if you want to load all projects at startup like yabIDE, this slow down the program start.
If you want load all at startup:
Example
-view on the left with a listbox
-stackview on the right with the max stacks count of open documents. Place on all a textedit.
-readout the projects folder and list them on the listbox.
-selecting a project in the listbox and change to the coresponding stack.
Hello,
I have a few bugs in my application regarding saving and closing files at the moment. This since I use several files.
I think it was the delete column command that was complicating things with me. That must change the kind of “ID” of a row in the column box.
Also, I can’t find any way to modify a row of a columnBox.
Example: With the Save As button, I will change the name of the file in the ColumnBox
The only way I have found is to delete the row and add a new one. Is this the right way?
I will post my source but it’s long now. Dont use important file for testing it and the New command don’t work at all for now.
 window open 50, 50 to 950,700, "View", "CCompiler"
    layout "all", "View"
    menu "File","Close","X","View"
    menu "Run","Compile","K","View"
    menu "Run","Terminal","T","View"
    menu "Run","--","","View"
    menu "Run","Make Löve","","View"
    menu "Options","Build Directory","B","View"
    LinkLib$=""
    current_file$=""
    BuildDirName$=""
    FilePosition=1
    //Splitview crée 3 vues ajustables
    splitview 0,22 to 900,637, "FileSplit", true, false, "View"
    splitview 0,0 to 660,614, "TxtSplit", false, false, "FileSplit2"
    SPLITVIEW SET "FileSplit", "Divider", 150
    SPLITVIEW SET "TxtSplit", "Divider", 500
    COLUMNBOX 0,0 TO 145,612, "FileBox", true, "resizable no-sorting", "FileSplit1"
    columnbox column "FileBox", "File Name",1, 140, 60, 80, "align-left"
    columnbox column "FileBox", "File Path",2, 250, 60, 180, "align-left"
    //Initialisation de pages.
    MAXFILE=3
    stackview 0,0 to 743,h-150, "Stack", MAXFILE, "TxtSplit1"
    FileNumber=1
    for FileNumber=1 to MAXFILE
    	print ("alo")
    	textedit 0,0 to 743,h-150, "TextEd"+str$(FileNumber),3,"Stack"+str$(FileNumber)
    	textedit color  "TextEd"+str$(FileNumber),"bgcolor",255,255,255
    next FileNumber
    FileNumber=1
    //textedit 0,0 to 743,h-150, TextEd$, 3, "Stack1"
    //textedit 0,0 to 743,h-150, TextEd1$,3,"Stack2"
    LISTBOX 0,0 to 743,107, Log$,3, "TxtSplit2"
    inloop = true
    while(inloop)
    	if(FileNumber>0)then
    	LineCount=TEXTEDIT GET "TextEd"+str$(FileNumber),Option$
    	LineNumber = TEXTEDIT GET "TextEd"+str$(FileNumber), Option$
    	endif
    	msg$=message$
    	switch msg$
    		inloop = false
    	break
    		inloop = false
    	break
    		filename$ = ""
    			//Open the file
    		OpenFile()
    		//BuildDirName$=""
    		break
    	case "View:Options:Build Directory|"
    		ChangDir=1
    		BuildDir()
    	break
    		SaveFile()
    	break
    		SaveFileAs()
    	break
    		LISTBOX CLEAR Log$
    		SaveFile()
    		BuildDir()
    		print ("gcc "+filename$+" -o "+BuildDirName$+"/build "+LinkLib$)
    		if(LinkLib$="")then
    			if(system("gcc "+filename$+" -o "+BuildDirName$+"/build 2> /boot/home/log.txt")=0)then
    			endif
    		elseif(system("gcc "+filename$+" -o "+BuildDirName$+"/build "+LinkLib$+" 2> /boot/home/log.txt")=0)then
    		endif
    		while(!eof(1))
    		wend
    		close #1
    	break
    		NewFile()
    	break
    	case "View:File:Close|"
    		CloseFile()
    	break
    		system("Terminal "+BuildDirName$+"/build")
    	break
    	case "View:Run:Terminal|"
    		system("Terminal")
    	break
    		Linking()
    	break
    	break
    	end switch
    	//Si on sélectionne un fichier dans la FileBox
    	if(instr(msg$, "_Select")) then
    		currentRow = columnbox get "FileBox"
    		currentItem$ = columnbox get$ "FileBox", 2, currentRow
    		print "Row: "+str$(currentRow)
    		print columnbox get$ "FileBox", 1, currentRow
    		filename$=currentItem$
    		WINDOW SET "View", "Title", "CCompiler "+filename$
    		STACKVIEW SET "Stack", currentRow
    		FilePosition=currentRow
    	endif
          	//Si on double-click
           	if(instr(msg$, "_Invoke")) then
           	endif
           if(instr(msg$, "Quit"))then
           	inloop = false
           endif
    	Update()
    wend
    window close "View"
    Exit
    //-------------------------------------------------Functions---------------------------------------------
    sub Update()
    	draw flush "View"
    	return
    end sub
    sub CloseFile()
    	if(COLUMNBOX COUNT "FileBox">0)then
    		textedit clear "TextEd"+str$(FilePosition)
    		COLUMNBOX REMOVE "FileBox", FilePosition
    			COLUMNBOX SELECT "FileBox", 1
    	endif
    end Sub
    sub SaveFile()
    	FileDir()
    		SaveFileAs()
    		SaveFileAs()
    	else
    		file2save$=textedit get$ "TextEd"+str$(FilePosition)
    		print #1 file2save$
    		close #1
    	endif
    end sub
    sub SaveFileAs()
    	file2save$=""
    	filename$=""
    	print("Filetosave"+filename$)
    	print("Position:"+str$(FilePosition))
    	file2save$ = textedit get$ "TextEd"+str$(FilePosition)
    		COLUMNBOX REMOVE "FileBox", currentRow
    		FileDir()
    		columnbox add "FileBox", 1, FileNumber, 18, current_file$
    		columnbox add "FileBox", 2, FileNumber, 18, filename$
    		print #1 file2save$
    		close #1
    end sub
    sub FileDir()
    			cpt=0
    			spacetxt$=""
    				cpt=cpt+1
    			wend
    			print current_path$
    			print current_path$
    			print current_file$
    end sub
    sub NewFile()
    	if(selected=1)then
    		LISTBOX CLEAR Log$
    		filename$="/boot/home/main.c"
    		current_file$="main.c"
    		SaveFile()
    		LISTBOX CLEAR Log$
    		current_file$=""
    		BuildDirName$=""
    	endif
    end sub
    //Option menu
    sub Linking()
    	quitting=0
    	while(not quitting)
    		m$ =message$
    			quitting =true
    		endif
    	wend
    	print LinkLib$
    end sub
    sub BuildDir()
    	if(BuildDirName$="" or ChangDir=1)then
    		BuildDirName$ = FILEPANEL "Load-Directory", "Select the Build Directory", BuildDirName$,""
    		ChangDir=0
    	endif
    end sub
    //Test if a file is open
    sub Opened()
    	test=1
    	NumberOfRows = COLUMNBOX COUNT "FileBox"
    	if(NumberOfRows>0)then
    		for cpt=1 to NumberOfRows
    			Item$ = COLUMNBOX GET$ "FileBox", 2, cpt
    			if(filename$=Item$)then
    				test=0
    				cpt = NumberOfRows
    			else
    				test=1
    			endif
    		next cpt
    	endif
    end sub
    sub OpenFile()
    		Opened()
    		if(test=0)then
    			alert "The file "+filename$+" is already open", "Ok","Stop"
    		elseif(COLUMNBOX COUNT "FileBox"<MAXFILE)then
    			//Si un fichier est sélectionné
    				FileDir()
    				//Gestion de la nouvelle vue
    				if(NumberOfRows<MAXFILE)then
    						FileNumber=NumberOfRows+1
    				endif
    				COLUMNBOX SELECT "FileBox", FileNumber
    				while(!eof(1))
    				textedit add "TextEd"+str$(FileNumber), newline$ + "\n"
    				wend
    				//close file
    				close #1
    				textedit set "TextEd"+str$(FileNumber), "gotoline", 1
    				stackview set "Stack", FileNumber
    			endif
    		else
    			alert "You have open the maximum of files!", "Ok", "Stop"
    		endif
    end sub
Thank you.
The columnbox is realy simple and have no edit options. Thats why i use more a listbox.
You need to remove the old one and add a new one. If you want the entrys in the alphabetical order you need to clean the complete columnbox and set the entries new into it.
I have change my code without remove the row in the column box but adding a new row in the same place. And that still work for now. But don’t sure it will give me some bugs in the futur
That’s seem to work for this SaveAs example.
In Yab IDE the file panel seem to be also a column box.
Hi Kitsune,
i the Yab-IDE the file-panel is a columnbox without sorting function. You can deactivate the sorting function. I think, you doesn’t get errors in the future.
Regards lorglas
You need to know that columnbox entry is for the right textedit if you use more then one textedit.
Yes that’s the case here.
I put my work as example here, I solved some trouble I think
This is certainly not perfect but it’s progressing step by step:
menu "Run","Make Löve","V","View"
menu"Help","About","B","View"
//w = window get "View", "width"
LinkLib$=""
current_file$=""
BuildDirName$=""
MAXFILE=5
stackview 0,0 to 743,h-150, "Stack", MAXFILE+1, "TxtSplit1"
FileNumber=1
	print ("Generating text editor:"+str$(FileNumber))
next FileNumber
FileNumber=1
STACKVIEW SET "Stack", FileNumber
columnbox add "FileBox", 1, 1, 18, "New"+str$(FileNumber)
columnbox add "FileBox", 2, 1, 18, ""
currentRow=1
inloop = true
while(inloop)
	//Get the counter of lines
	if(currentRow>0)then
		LineCount=TEXTEDIT GET "TextEd"+str$(currentRow),Option$
		LineNumber = TEXTEDIT GET "TextEd"+str$(currentRow), Option$
	else
		LineNumber=0
		LineCount=0
	endif
	Update()
	msg$=message$
	switch msg$
		inloop = false
	break
		inloop = false
	break
		filename$ = ""
			//Open the file
		OpenFile()
		break
		ChangDir=1
		BuildDir()
	break
		SaveFile()
	break
		SaveFileAs()
	break
		LISTBOX CLEAR Log$
		SaveFile()
		BuildDir()
		GCC_LINE$="gcc "+filename$+" -o "+BuildDirName$+"/build "+LinkLib$
		LISTBOX ADD Log$, GCC_LINE$
		if(LinkLib$="")then
				LISTBOX ADD Log$, "Compilation of "+filename$+" Successfull!"
			endif
		endif
		while(!eof(1))
		wend
		close #1
	break
		NewFile()
	break
		CloseFile()
	break
	break
		system("Terminal")
	break
	case "View:Run:Make Löve|"
		MakeLove()
	break
		Linking()
	break
	break
	end switch
		FileType(filename$,currentRow)
	endif
       	endif
       	inloop = false
       endif
wend
window close "View"
Exit
sub Update()
	draw flush "View"
	return
end sub
sub CloseFile()
	//If more than 0 Row in the column Box then launch the close command
	NumberOfRows=COLUMNBOX COUNT "FileBox"
		Selected=alert "Would you like to save your work before closing the file?", "Yes", "No", "Cancel", "info"
		if(Selected=2)then
			ClosingFile()
		elseif(Selected=1)
			SaveFile()
			ClosingFile()
		endif
	//	if(COLUMNBOX COUNT "FileBox">0)
	//		COLUMNBOX SELECT "FileBox", 1
	endif
end Sub
sub ClosingFile()
	textedit clear "TextEd"+str$(currentRow)
	for cpt=currentRow to NumberOfRows
		if(not(cpt+1>NumberOfRows))then
			TxtBuffer$ = textedit get$ "TextEd"+str$(cpt+1)
			TEXTEDIT ADD "TextEd"+str$(cpt),TxtBuffer$
			textedit clear "TextEd"+str$(cpt+1)
		endif
	next cpt
		COLUMNBOX SELECT "FileBox",1
	else
		STACKVIEW SET "Stack", MAXFILE+1
	endif
end sub
sub SaveFile()
		filename$ = COLUMNBOX GET$ "FileBox", 2, currentRow
		PathFind(filename$)
			SaveFileAs()
			SaveFileAs()
		else
			file2save$=textedit get$ "TextEd"+str$(currentRow)
			print #1 file2save$
			close #1
		endif
	else
		alert "No file to save!","Ok","Stop"
	endif
end sub
sub SaveFileAs()
		file2save$=""
		filename$=""
		PathFind(filename$)
		print("Position:"+str$(currentRow))
		file2save$ = textedit get$ "TextEd"+str$(currentRow)
	//	COLUMNBOX REMOVE "FileBox", currentRow
		//Get the current choosed file name
		PathFind(filename$)
		columnbox add "FileBox", 1, currentRow, 18, current_file$
		columnbox add "FileBox", 2, currentRow, 18, filename$
		print #1 file2save$
		close #1
	else
	endif
end sub
sub NewFile()
	FileNumber=FileNumber+1
	if(NumberOfRows>=MAXFILE)then
		alert "You have reach the maximum of files","Ok","Stop"
	else
		columnbox add "FileBox", 1, NumberOfRows+1, 18, "New"+str$(FileNumber)
		columnbox add "FileBox", 2, NumberOfRows+1, 18, ""
		COLUMNBOX SELECT "FileBox", NumberOfRows+1
		STACKVIEW SET "Stack", NumberOfRows+1
		LISTBOX CLEAR Log$
	endif
end sub
//Option menu
sub Linking()
	quitting=0
	while(not quitting)
		m$ =message$
			quitting =true
		endif
	wend
	print LinkLib$
end sub
sub BuildDir()
		ChangDir=0
	endif
end sub
sub Opened()
			if(not(filename$="") and filename$=Item$)then
				cpt = NumberOfRows
				return true
			endif
		next cpt
		return false
	endif
end sub
sub OpenFile()
		if(Opened())then
				WINDOW OPEN 200,200 TO 500,250, "Loading", "Loading File"
				WINDOW SET "Loading", "Look", "Modal"
				DRAW TEXT 30,30, "Loading the file: "+filename$, "Loading"
				PathFind(filename$)
				endif
				FileType(filename$,FileNumber)
				while(!eof(1))
				wend
				//close file
				close #1
				window close "Loading"
			endif
		else
		endif
end sub
sub MakeLove()
	selected = alert "Select your main.lua file or your Love project directory where is it.", "Single file", "Love Project Directory", "Cancel", "info"
	if(selected=1)then
		cpt=1
		while(cpt)
			LoveFile$=""
			LoveFile$ = filepanel "load-file", "Open your main.lua file", current_path$,""
			filename$=LoveFile$
			PathFind(filename$)
			LoveFile$=system$("basename "+LoveFile$)
			LoveFile$=rtrim$(LoveFile$)
			if(LoveFile$="main.lua")then
				print "super!"
				cpt=0
			elseif(LoveFile$="")
				cpt=0
			elseif(not (LoveFile$="main.lua"))then
				alert "Please choose a main.lua file!", "Ok","warning"
			endif
		wend
			WINDOW OPEN 200,200 TO 500,250, "LoveMaking", "Making LOVE"
			WINDOW SET "LoveMaking", "Look", "Modal"
			DRAW TEXT 30,30, "Making Love File...Please Wait", "LoveMaking"
			system("cd "+current_path$+" && rm -f main.love && zip -J -9 -r -T main.love main.lua")
			window close "LoveMaking"
			system("cd /bin/x86/ && love "+current_path$+"main.love")
			LoveFile$=current_path$+"main.love"
		endif
	elseif(selected=2)then
		cpt=1
		while(cpt)
			LoveFile$=""
			LoveFile$ = filepanel "Load-Directory", "Love Project Directory", current_path$,""
			if(LoveFile$="/boot/home")then
				selected=alert ("It seem that your choose the /boot/home directory as a Love project folder. This is dangerous!"),"Continue","Choose an other directory", "Cancel", "Stop"
				//Continue
				if(selected=1)then
					cpt=0
				//Cancel
					LoveFile$=""
					cpt=0
				//Other directory
				elseif(selected=2)
					cpt=1
					selected=0
				else
				cpt=0
				endif
			endif
			//Searching for the main.lua file
			Item$=system$("cd "+LoveFile$+" && dir main.lua")
			Item$=rtrim$(Item$)
			if(Item$="main.lua")then
				cpt=0
			elseif(not(LoveFile$=""))
				alert "The file main.lua not found in this directory. Please select an other one.", "Ok", "Info"
				cpt=1
				cpt=0
			endif
		wend
		if(not(LoveFile$=""))then
			system("cd "+LoveFile$+" && rm -f main.love && zip -J -9 -r -T main.love *")
			system("cd /bin/x86/ && love "+LoveFile$+"/main.love")
			LoveFile$=LoveFile$+"/main.love"
		endif
	else
		LoveFile$=""
	endif
	print ("Your Love File is in: "+LoveFile$)
	selected = alert "Would you like to build the love file for making it executable?", "Build it!","No", "Recreate a Love File", "Info"
		if(selected=1)then
			LoveBuild$=""
			LoveBuild$ = filepanel "save-file", "Save Executable", "/boot/home", "LoveBuild"
			if(not(LoveBuild$=""))then
				WINDOW OPEN 200,200 TO 500,250, "BuildLove", "Build LOVE"
				WINDOW SET "BuildLove", "Look", "Modal"
				DRAW TEXT 30,30, "Making Love Executable...Please Wait", "BuildLove"
				system("cat /boot/system/bin/x86/love "+LoveFile$+" > "+LoveBuild$+" && chmod 777 "+LoveBuild$)
				window close "BuildLove"
				PathFind(LoveBuild$)
				system("open "+current_path$)
			endif
		elseif(selected=3)
			MakeLove()
		endif
	endif
end sub
sub PathFind(path$)
			current_file$=system$("basename "+path$)
			cpt=0
			spacetxt$=""
				cpt=cpt+1
			wend
			print current_path$
			current_path$=path$
			print current_path$
			print current_file$
end sub
sub FileType(type$,Row)
	textedit color  "TextEd"+str$(Row),"bgcolor",255,255,255
	textedit color  "TextEd"+str$(Row),"textcolor",0,0,0
	if(right$(type$,2)=".c")then
		print "This is a C file"
		textedit color  "TextEd"+str$(Row),"color2",255,0,0
		textedit color  "TextEd"+str$(Row),"color1",0,0,255
		textedit color  "TextEd"+str$(Row),"color3",0,120,0
		textedit color "TextEd"+str$(Row),"color3","printf"
		textedit color "TextEd"+str$(Row),"color1","int"
		textedit color "TextEd"+str$(Row),"color1","char"
		textedit color "TextEd"+str$(Row),"color1","double"
		textedit color "TextEd"+str$(Row),"color1","float"
		textedit color "TextEd"+str$(Row),"color3","main"
		textedit color "TextEd"+str$(Row),"color3","include"
		textedit color "TextEd"+str$(Row),"color2","return"
		textedit color "TextEd"+str$(Row),"color2","if"
		textedit color "TextEd"+str$(Row),"color2","else"
	elseif(right$(type$,4)=".lua")then
		print "This is a LUA file"
	elseif(right$(type$,4)=".txt")then
		print "This is a Text File"
		textedit color  "TextEd"+str$(Row),"color1",0,0,0
		textedit color  "TextEd"+str$(Row),"color2",0,0,0
		textedit color  "TextEd"+str$(Row),"color3",0,0,0
		textedit color  "TextEd"+str$(Row),"color4",0,0,0
	else
		print "This is a unrecognized file type"
	endif
end sub
If you encounter some troubles, please put the step of the way you encounter it.
Thanks.
Yes I had do it cause that’s making trouble about Files management. Thanks
Your app looks good. Is good, that you make a editor for löve2D. I say, that i will do that, but at the moment i have no time.
Yes I have put a Make love button in it, I work on it for “compiling” but I don’t work on the syntax for now.
I have updated the code , the button making love work now. That create a Love file named main.love in the same directory of the main.lua file
And launch Love after it making. You can build the love file to an executable. For now that always overwrite a /boot/home/MyLoveBuild file (for the executable).
You must have Love Installed. Zip too (command line) and GCC for compile in C. Here love is in the /bin/86 folder of Haiku (32bits version).
I don’t know if that work on 64bit haiku system. Cause the love directory it’s not the same I think. Also don’t know if YabIDE work on 64Bits.
screenshot1
