[quote=Giova84]If i use “jam @haiku-cd” i get the same errors…
In any way, I’ve found this topic: https://www.haiku-os.org/community/forum/making_bootable_iso_using_mkisofs_under_haiku
I have used the same command: mkisofs -R -max-iso9660-filenames -b haiku-boot-floppy.image -c boot.catalog -o /Haiku-Custom.iso /boot
Then i have booted up this iso file inside Virtualbox:
Once the desktop is show up, i’ve also found the same trouble: most of attributes seem lost. The folders are with grey icon and applications with the default icon
Screenshot:
I’ve also found that the “find” function no longer work inside Haiku.
Where is the problem and how can i solve?[/quote]
sorry dude I had a stupid moment
first question did you check out the trunk ?
did you add 2 folders to your system to build hybrids ?
did you configure those folders
also
jam is the " build this command" everything behind it is the how to build and what to build
so
jam -j12 -q @alpha-cd
build 12 threads stop on errors the alpha iso image
conversly you could skip the j12 and the q and just type
jam @alpha-cd
theres a whole bunch of these arguments you can set.
anyways basics
jam
@alpha-anyboot
@alpha-raw
@alpha-cd
Those will build the Alpha images with webpositive, wonderbrush etc preinstalled
@nightly-cd
@nightly-raw
@nightly-anyboot
will build the stripped down nightly with less software
the -jxx is a way to set threads working on the build
so -j1 is one thread
-j12 is 12 threads
-q means to stop the build on any errors
-a will force the build system to rebuild all targets
Useage is like so
jam “build the following” -j12 " twelves worker threads" -a " rebuild or build all targets in the jam file" -q " stop on errors"
@alpha-cd " makes a alpha iso image
sp like this
jam -j12 -q -a @alpha-cd
Now to build haiku unless your just going for a straight build " which I haven’t done in a long time now so don;t bother asking me how"
You’ll need to go to the folder generated.x86gcc2 or generated.x86gcc4 you should have created those 2 folders should be in boot/home/haiku/haiku if you svn donwloaded the trunk and followed all the step on configuring for hybrids…
so in terminal cd “change directory” to the folder "example cd /boot/home/haiku/haiku/generated.x86gcc2 then use the above commands and it should build. On haiku this is pretty easy, on other OS’s there a bit more invovled, since I don’t build on a different OS’ I am spared the headaches of doing so.
