He is trying to use it on 32 bits, and currenty, only the 64 bits version is available on the repos.
But in any case, I doubt pybind11 (that the Haiku-PyAPI require) will work with GCC2, @TmTFx. If you really can’t move away from GCC2, I would suggest you to build Python 2.7.18 locally, and see if that allows you to keep using Bethon and the rest of your apps. Edit: I got confused while reading him. See @coolcoder613 comment below.
I think @TmTFx means:
Thanks for the replies, I’m trying to install Haiku-PyAPI under haiku-32 bits (walter). It(Haiku-PyAPI) needs to use gcc greater than 4.8. How can I tell Jam not to use the default gcc (2.95) (i.e. not using /bin/gcc and use instead /bin/x86/gcc)?
I also created a new Haiku64bit VM and I installed from repos Haiku-PyAPI… It works Thank you a lot @coolcoder613. If able I’ll contribute as I can! I start playing with Haiku-PyAPI and, if possibile, porting my apps!
Thank you
