How to get Web Positive? Why is it not in Nightly Builds?
Updated to a Nightly Build and noticed it no longer has Web Positive. Where can I get it from?
Also, why is this browser no longer part of the Haiku builds?
tj
Hi tj,
You can install Web Positive - as well a host of additional apps using the installoptionalpackages command in terminal.
If memory serves type installoptionalpackages -l to list all the packages available for install (although installoptionalpackages -? should give you a syntax list)
Hope that helps.
