How to download using WebPositive
I feel like a boob, but I can’t seem to download any of the apps and programs I want to install. I’m using Webpositive and can’t see on that page, for instance, the download button, or how to.
https://www.haiku-os.org/docs/userguide/en/applications/haikudepot.html
Can anyone help? Thanks
ist not to install with a Browser. select haikudepot in you application menu
Hi,
WebPositive has a download function just like any other web browser. However, our userguide does not provide links to the apps since they are installed in the OS already.
If you are running Haiku version Alpha 4.1 (or older), the HaikuDepot application was not available for it yet. You need to install a recent nightly build from http://download.haiku-os.org. Then it will be available from the main menu.
