I am using Haiku, since two months. It was a great experience but I’ve seen a lack of good apps. That’s why I thought of developing apps for Haiku. I need someone who can just throw some lights, how to do this and what software I will need. I will try my best to make Haiku a modern age Operating System. Thanks.
You can use yab to make programs under Haiku. Here is a beginner’s book : https://www.smashwords.com/books/view/691720
Hello and welcome!
There are a lot of info about development:
https://www.haiku-os.org/development/
I would suggest specially this guides:
https://www.haiku-os.org/development/learning_to_program_with_haiku
https://www.haiku-os.org/development/programming_with_haiku
Just start to do something you need for your daily work, thats the best start
Here are many people who can help you development, just join the mailing list of developers: https://www.haiku-os.org/development
For cpp you can take a look here, just a beginers guide but here you can see using api deleoment: https://www.haiku-os.org/development/learning_to_program_with_haiku
macadoum1h: You can use yab to make programs under Haiku. Here is a beginner’s book : https://www.smashwords.com/books/view/691720
Take a look on our knowledge base http://www.besly.de
Perhaps this will help: http://clasquin-johnson.co.za/michel/haiku/blog/2014/why-you-should-be-writing.html Just ignore the references to Haikuware - That site no longer exists.
