How to compile and run HaikuDepot?
I am new to Haiku OS development and I want to contribute to it in GSOC 2019. I want to work on modular edit text. The idea is as follows:
The current solution for text editing in Haiku is the BTextView. It is a rather simple view providing basic text editing features and limited styling. This is, however, not powerful enough for most serious uses. The goal of this project is to design a complete replacement for BTexView, which should be designed to cover more use cases.
The existing work done is in Haiku Depot as mentioned below:
β€œThe HaikuDepot application includes preliminary work on a rich text view, which it uses to provide the description of packages. This could be used as a starting point for this work.”
So to get started I want to know how to compile and run HaikuDepot and see how rich text view is implemented in HaikuDepot.
For this you need to download haiku source tree, see https://www.haiku-os.org/guides/building/get-source-git. After that run ./configure and jam -j2q HaikuDepot.
