How to choose wifi network?
Hi,
I just got Haiku booting off of an SD card on an EeePC1018.
The Network applet says /dev/net/atheroswifi/0: Ready, and I can apparently access the internet.
The problem is, at no point did I specify what wireless network I wanted to join, and for the life of me I cannot find any preferences pane to even tell me the network I’m on, much less change it. Is there a command to do this, or an application I am missing, or what?
The Network preferences just lists such as the IP/gateway/etc, with an “Apply” button. Nothing about the SSID.
Caj
There is a command line tool.
http://dev.osdrawer.net/attachments/download/225/haiku-wlanconfig-svn-r34791.zip
Try:
setwep /dev/net/atheroswifi/0 nameofconnection password:
Choose dhcp in network setup
