How to apply multiple bitmaps in BView with using alpha?
I use an object from BView class to display a PNG file as a BBitmap. I use a second BView object to display a second PNG image on the first one. That works well.
After it I want to use alpha capability as the second image has irregular outline not a simple rectangle (let’s talk about a circle on the second image).
Here is the code as I draw second bitmap (stored in variable PointPic).
SetDrawingMode(B_OP_ALPHA);
SetBlendingMode(B_PIXEL_ALPHA, B_ALPHA_OVERLAY);
DrawBitmap(PointPic, B_ORIGIN);
Where it was transparent surface on the bitmap before now I can see white not pixels of first bitmap below the second bitmap.
So, how should I use these methods properly? Could you give me some helps?
Cozi
Make sure your second bitmap is in the B_RGBA32 colorspace (that is, alpha channel was correctly loaded).
Other than that I think your code should work.
Well, I have made some efforts.
I created two BView object called BackView and FrontView. Each of them has different bitmap to display (BackPic, FrontPic).
BackPic:
minta1
FrontPic:
minta2
I put FrontPic on BackPic and FrontPic has a transparent background. These images were made by WoderBrush in Haiku.
As my program starts it uses alpha channel but main problem is the backgorund. I supposed that background picture would be BackPic for FrontPic but desktop got background! I cannot imagine how could be happened. I have some screenshots:
Screenshot_01_from_Haiku_20220411
Screenshot_02_from_Haiku_20220411
My code is here:
#include “MainWindow.h”
#include <Application.h>
#include <Bitmap.h>
#include <TranslationUtils.h>
#include <View.h>
#include <Entry.h>
#include <File.h>
#include <Path.h>
class FrontView : public BView
public:
FrontView();
void Draw(BRect);
BBitmap *FrontPic;
class BackView : public BView
public:
BackView();
void Draw(BRect);
BBitmap *BackPic;
FrontView::FrontView()
: BView(BRect(0, 0, 200, 100), “BackView”, B_FOLLOW_NONE, B_WILL_DRAW)
FrontPic = BTranslationUtils::GetBitmapFile("/boot/home/Projects/X3/minta2.png");
void FrontView::Draw(BRect)
DrawBitmap(FrontPic);
BackView::BackView()
: BView(BRect(0, 0, 200, 200), “BackView”, B_FOLLOW_NONE, B_WILL_DRAW)
BackPic = BTranslationUtils::GetBitmapFile("/boot/home/Projects/X3/minta1.png");
void BackView::Draw(BRect)
DrawBitmap(BackPic);
FrontView *fv;
BackView *bv;
MainWindow::MainWindow(void)
: BWindow(BRect(100, 100, 500, 400), “Main Window”, B_TITLED_WINDOW, B_ASYNCHRONOUS_CONTROLS)
fv = new FrontView();
bv = new BackView();
fv->SetDrawingMode(B_OP_ALPHA);
fv->SetBlendingMode(B_PIXEL_ALPHA, B_ALPHA_OVERLAY);
fv->SetViewColor(B_TRANSPARENT_32_BIT);
bv->AddChild(fv);
AddChild(bv);
void MainWindow::MessageReceived(BMessage *msg)
switch (msg->what)
default:
BWindow::MessageReceived(msg);
break;
bool MainWindow::QuitRequested(void)
be_app->PostMessage(B_QUIT_REQUESTED);
return true;
How can I fix this problem?
I think you need to set the B_TRANSPARENT_VIEW flag on FrontView, otherwise it will draw its own background (even if you ask it to be transparent) and this results in strange things.
B_TRANSPARENT_VIEW makes sure the containing view is drawn first.
Here is my modified code:
: BView(BRect(0, 0, 200, 100), “FrontView”, B_FOLLOW_NONE, B_WILL_DRAW | B_TRANSPARENT_VIEW)
Make with some errors:
After it I searched for keyword “B_TRANSPARENT_VIEW” with Google but I have not found any measurable results. Does it exist?
I’m starting to get lost. Could you help a bit, again?
No developer here, but maybe something useful here?
Thank you!
BeOS didn’t support transparent views.
Well, new strategy is needed :slight_smile:
Ok, next step: I will try manage bitmaps with transparency and the result (agregated) bitmap will be displyed in a single BView.
I am going to spend some time to make a second demo. Thanks, again!
But arent you using Haiku? It does support transparent views.
I think you only read that line? (not the full commit) :slight_smile:
Ok. I got a lot of experience.
  1. I should read all of the text, extensively :slight_smile:
  2. My working code is here (partly):
: BView(BRect(0, 0, 200, 100), “FrontView”, B_FOLLOW_NONE, B_WILL_DRAW | B_TRANSPARENT_BACKGROUND)
Screenshot_Haiku_03_20220411
  1. The magical flag was B_TRANSPARENT_BACKGROUND
  2. This flag is not there in the documentation ( The Haiku Book: BView Class Reference , description of BView() constructor) or I live in an alternative galaxy, far far away …
  3. There must be a lot of luck during software development, e.g. questions sould be asked well and there sould be kind people answering them :slight_smile:
So, thank you, next chapter is coming!
