HiQDock - fixes and improvements
Following up on this old app and thread at ( HiQDock ... New Dock coming soon ) …
I’m happy to announce a new version of HiQDock that fixes a big issue - the dock options window was blank and also the “Change Icon Image” window was blank.
Moreover, thanks to @3dEyes’s great work in creating the hviftools, all icons are now smoothly scaled.
(Technically: this means that as soon as you add a new launcher, the icon is displayed without pixelation as it was in previous versions of the HiQDock) - you can still replace the icon launcher with a custom image (.svg or .png) - simply place any custom icons you want to use in ‘’/boot/home/config/settings/HiQDockIcons" folder.
Download the package here: hiqdock-distro/hiqdock-1.0.1-1-x86_64.hpkg at main · hey68you/hiqdock-distro · GitHub
Important known issue that I haven’t fixed yet:
You MUST make sure in your Qt6 Configurator that “QML” is set to “Use Software 2d context renderer” as in this screenshot. (otherwise the HiQDock app will crash)
For some reason when the HiQDock is running on Haiku that is running in a VM (QEMU/UTM) - tried on Linux Zorin host and on MacOSX UTM host, the click and drag isn’t working to move the launchers to new locations
…works fine on real hardware :puzzle_piece: :scream:
:rofl: okay Gemini helped:
On UTM:
Change the pointing device / input mode from USB Tablet (or VirtIO Tablet) to PS/2 Mouse or USB Mouse.
On Zorin (Ubuntu)
If using Virt-Manager, open VM Details > EvTouch USB Graphics Tablet (or Tablet input) > Remove the device, then add a standard USB Mouse input device instead.
