There is a time zone difference in the world, most of these posts happened during my nap time
@Starcrasher
I fixed the .PackageInfo version (part of the tag)
@Begasus
Regarding the $dataDir/Medo/Languages/, I understand the benefit to users with this approach, but it does cause a minor inconvenience to developers since the entire project isnāt self contained in a master directory from which one can build from, manage git, download and test/execute. I do handle 2 paths for file lookup (the /system/apps path and the user ~/config/settings path), I guess a 3rd is not out of the question. Iām just old school when it comes to not dumping data all over the users hard disk and prefer to keep things neatly contained, but will accept what the expected norms and user expectations are.
Thank you all for your help. Lets see if the freshly added tag helps with the recipe the wonderful community has helped create. Next weeked Iāll try to build the 32 bit version as well (if I can access my friends PC, another quarantine here in Melbourne, so no socialising).
@victordomingos
Hi Victor. I havenāt forgotten to include it (I also have Ukraine translation), I have been insanely busy during the last couple of weeks and I just havenāt got around to it yet. Iāll try to get around to it this Weekend. It should be OK, and with the new system will be much easier to integrate. Iāll let you know when itās done. Thanks again.
OK, with some small changes to @extrowerkās PR to set the tagged release Iāve been able to build it on 32-bit
One thing I needed to change is in the jamfile:
C++FLAGS += -I/boot/system/develop/headers/freetype2 ;
to
C++FLAGS += -I/boot/system/develop/headers/x86freetype2 ;
Is there a way to let it look for freetypeās pkg-config file so this hardcoded path wouldnāt be needed? (not familiar with jam)
Itās an option, but since 32-bit isnāt really supported (crashed a few times here) maybe a āPATCH()ā and āsedā could be added?
Best option still would be to have some check with pkg-config imho ⦠(not sure on how other libraries are detected)?
Thanks for the tag @Zenja! As for the layout, having a quick look at the package created, maybe it would be nice to have most of the data installed to $dataDir, locales to $dataDir/locales, add-ons to $addOns
Didnāt look into the source on how itās handled, but could be an option
Having the āappā only in $appsDir gives the advantage also to start it from Terminal
IMO, native apps should keep all their data under $appsDir; the other directories are only useful if the data is shared between packages for some reason.
