Yes, I moved the file:
/boot/home/config/settings/system/app_server/workspaces
To a different folder in my home directory and when I restarted, the video display was perfect.
That’s interesting. Thanks for the help.
Here is something strange I found after playing around with the sound settings. On the PC box there are two audio out ports. One on the front of the box, and one on the back. When I had Windows installed I had plugged in external speakers to the back port. So I was not sure why Haiku wouldn’t okay sound. Then I decided to plug some headphones into the front port and had some StreamRadio going, and the music came through just fine. That’s great. Now I just have to figure out more about the audio driver or the media settings to figure out why the back port is not being recognized.
It’s probably a routing problem in HDA driver, not sure if it allows to remap output ports using Media preflet.
